Tips and Tricks
Quick second tie in for lateral movement with a flat rope angle, secondary tie in without ocupying your lanyard for leapfrogging when you can't rely on your main TIP as you advance, and it is great for returning from more vertical limbwalks/your primary TIP after removing a redirect. The friction makes your wrench system walk back up your line as you descend into it.
You just unclip the hitch and toss it around a branch. If it is oriented properly, there is a manageable amount of friction as the slack rolls over the loaded portion.
how do you like the samson mercury rope
I like it a lot. It broke in quickly and now has the best feel of any static kernmantle I have tried. It's not bad at tying knots at all.
It also grabs everything and tries to tie knots everywhere. Something about how stiff it is just makes it harder to pull over bends and it is always tangled.
This tip brought to you by Derrik Martin....When redirecting a single line, use a munter hitch on the biner. This dosent allow the climbers weight to pull branch unions together or apart. rope then acts like a brace. a definite game changer...allowing you to redirect into much smaller limbs.
Also doesn't side load the carabiner
Tom, I remember seeing your magnet/scabbard idea a long time again! What took you so long to post that great idea. You have others you are holding out on I know like the connector to the rope grab. Thanks again for the seed thought on the adjustable rope bridge. It is a change from my frog walker type system and I have entered the world of bungee but your thought on this has made the transition good.
I put a harbor freight hundred pound magnet on the outside of my scabbard. It not only keeps my handsaw from falling out but if I'm breaking back a big limb in an awkward position I can just slap the saw onto the outside of the scabbard with out looking and it stays put. Once I'm comfortable I can put it back into the scabbard easy peasy
Transport Hitch (aka "Voodoo Hitch)
Also, as a safety, it should be 'locked-off' with the tail run back around the anchor and secured to the carabiner nearest the anchor … IMO
Hey, I didn’t realize anyone still knew how to do that! I have to find an excuse to set that up, show up the young guys again.
