Crimsonking
Been here a while
I start with it looking like the second photo, slide it over my toe to the middle, then adjust the knots to cinch down, creating one large loop on the bottom as well as one cinched loop. I then pull the large loop over my heel. After that I slide the knots to allow the best angle between vertical and horizontal loops to cradle the boot. The main, single loop ends up on top in front, where you would clip in. The two lines created by separating the “grapevine” make up the bottom and back straps.
I was amazed how snug it fit while being fairly easy to install and remove since I never changed it from its original use to try this.
So to sum up- how it looks in photo 2 is how it goes on and comes off. I won’t promise a video, only because I’ve never delivered on such a promise.
