Tips and Tricks
Burrapeg, your lost in your numbers and making assumptions based on your beliefs.
If you would just setup all 3 systems and climb up a ways, you would see it is not magic, just a simple truth that when the climber is doing the pulling, the math changes.
I have done this a number of times and, yes, I feel the advantage just like the rest of you. I am just not sure it is 3 to 1. I use all three of these setups almost every time I climb. I almost always use both SRT and DdRT in a good climb and I carry that homebrew QuickRoll every single climb for just what the drawing shows. But I am a curious type and like to know why there seems to be a difference. I see the factors that don't change at all, like the total rope used, how much the climber moves for the amount of rope in total (these are not mere beliefs but witnessed fact), and I have a fuzzy time reconciling that with the simple truth that you and I feel. I am not disputing the math changes somehow. I feel it same as you. But I ask a specific question in that previous note. Can you tell me how?
You may be over-thinking this.
The idea behind mechanical advantage (leverage) is very simple.
Work = Force x Distance
or
Distance = Work ÷ Force
or
Force = Work ÷ Distance
That is:
To lift 100kg 1 foot (the work) you can
a) pull 1 foot of rope with 100kg of force
b) pull 2 feet of rope with 50kg of force
c) pull 4 feet of rope with 25kg of force
etc...
"Force multiplyer" is a misleading term because, of course, you cannot suddenly multiply your strength. What you can do is multiply the distance you apply that same strength and thereby accomplish an equivalent amount of work.
OK, this is better, thanks Fulcrum. You are talking my language now. Equations and an exact answer are what I wanted to see, not vague assurances that it 'just works'. I am sure I have highjacked the thread long enough but I do appreciate the feedback, all of it. You guys know me, I have been on here for almost four years. I constantly build stuff; I don't just climb. Power ascenders half the size of a Wraptor, etc. that are midline attachable and work on any rope you shove in it. Other stuff too, my own versions of Bone, Wrench, etc. And gobs of other stuff having absolutely nothing to do with climbing. I have been a machinist, foundryman, and maker of stuff for over half a century. Guys like me just need to get all the way to the bottom of things if they don't seem quite right or are not obvious. We tend to apply this mindset to every single thing we do. We often do seriously over-think stuff, and on purpose. So, sorry if any of you found it tedious! Cheers, Stewart
Tips and tricks-
If you avoid conversations about mechanical advantage in climbing systems, your wife won’t get mad at how much time you spend on treebuzz.
Boy, have I got something funny to tell you guys about that! Ellen (wife) went to the three day camping/climbing event with me, the one where we sat thru the talk on MA I mentioned with Mumford, Dave from WesSpur, etc. Now, even looking at these equations above, one can still wonder exactly what the real picture is, to actually visually see why it is different for the groundie. And it was her that told me! We were sitting in bed last night after that all this discussion and I visited with her about it since it was still on my mind. In the middle of talking about it, she remembered something I had not. She said, 'what about when they put the groundie up in the air?'. And of course that is the true picture! It is the 2:1 that does not actually exist! It is always 3:1 even with the groundie! And the cheating, magic part is we add a bit of weight to the groundie to keep him on the ground. In the drawing, if the groundie weighs exactly half what the climber weighs, that is the only way he can hang in the air and not drop. It looks like 2:1 when he stands on the ground but that is because we hand him a feather to overcome the friction in the pulleys! Without pulley friction, we could walk over and just touch him with a finger to move him up or down and the climber would move opposite. It looks like 2:1 but the groundie is always one third part of the load. He is one third of total load at the tip even when he is on the ground pulling; he simply always has added weight. You would never have a groundie lift a climber in the drawing if he weighed half or less what the climber weighs. If he weighs half, and you have friction less pulleys, he lifts both himself and the climber an equal amount, which is half what the climber would rise if you reach up and hold the groundie still, where he is hanging. This where we get an apparent 2:1 with a groundie. And it takes no extra force. We just cheat a bit and make him heavier all the time so only the climber part of the load rises and that is the only part we care about.
Are you compelled to make this the most contorted, incomprehensible, never-ending discussion on climbing systems?
It's a climbing system! Stop bringing in groundies and magic.
Am I the only one here on the Buzz who has ever high-jacked a thread to clarify something? To discuss and analyze climbing systems is exactly what our TreeBuzz forum is in large part concerned with, isn't it? OK, so wrong thread right here, my apologies once again, in case you missed it the first time.
Went to a hands on splicing class, haven't paid money for a splice since. Only blood, sweat, and some tears.
Gotta say Samson's guides (written on their site & the corresponding Youtubes) were all I needed for nearly perfect splicing of an entire climbing & heavy-duty rigging kit....Combine this approach with Wesspur's clearance section and you can have a $1k "retail" rigging kit for well under half the price!
Surely already said but APTA/air-cannons!!! Not an unknown tip/trick but will say it's been a game changer for me, more advantage from this 1 piece of gear than any other (by FAR)
The "Treesqueeze" lanyard by Buckingham is a solid configuration, makes spurring-up safer & lets you climb around srt setting anchors on vertical stems w/o forks, but you don't have to pay $200 (of course) you can simply, say, take 20' of your favorite cordage, a friction hitch & some o-rings and now you've got an awesome "flipline/anchor lanyard"!!
The APTA is one of the few tools that I can honestly say was a total game changer for me...Being able to set access lines in excess of 200 ft has made my life soooo much easier. Some of the best money I have ever spent on a piece of tree gear.
But my wife is a physicist...
Lucky guy. Your wife probably tries to tell you how the universe works. Mine is a chemist who now works in health care... she keeps telling me why I should not eat or drink whatever crap I'm indulging in at the moment. If I read the label out loud, she tells me what all those ingredients are. It's amazing how they can make snacks and beverages without having to actually harm any actual food.
Fantastic! It appears that there are no classes scheduled. I would definitely travel to a class. Road trip! Any other classes/schools/instruction that someone can recommend? Thank you.
ZK
ZK
Wesspur has some good YouTube videos on splicing. Lookup class one double braid eye splice and 16 strand eye splice. I just use home made wire fids for everything. You can look up a fid lengths on Sampson's Fid Length Chart .
I'd virtually guarentee there is a splicing class in the bay area. think nautical, double braid is double braid regardless of its use
