R
rich_h
Guest
Now open the carabiner and clip it onto your anchor point on the harness. Depending on your harness this will either be onto a single ring, a single sliding D, a fixed D, or whatever you are using. The system will work on all of these configurations, you may just need to alter the dimensions of the anchor bridges.
When clipping onto the anchor point make sure that you are doing so in a way that does not make it possible for your smaller anchor bridge to fall off of the carabiner. This will be important so that you can extend the hitch side and reattach it safely.
I HIGHLY RECOMMEND USING YOUR SAFETY LANYARD WHEN YOU ARE MOVING BETWEEN MODES (EXTENDED, WORK) IT WOULD BE UNSAFE TO UNCLIP YOUR CARABINER WITHOUT BEING SAFELY ATTACHED TO THE TREE.
