Hard to tell from the picture, but it looks like has a loose braid and no coating, which would make it easy to pick the strands from contact with bark or branches. Any idea what it is made of, nylon, polyester, or something else?
The rope we climb on has to have a minimum breaking strength of 5400 lbs. For life support we use 10% of that for a working load limit of 540 lbs. Your rope manufacturer probably uses 5% making the break strength of possibly 1500 lbs.
For your use it is probably okay, but test your ideas low in the tree, and always inspect it every time before you use it.
