Rope Wrench - Hitch/Rope compendium.
That is a Michoacán that uses a stopper at the end, I use it when using the Wrench, can get it very compact and no need for HitchClimber, threw mine away months ago!
9756558F-6BF9-45F3-85E5-1A70EEDAF3D0.jpegTie the hitch, take the ends through the carabiner, cross them and take them to the back and tie a stopper knot. The knot acts as a tender by itself, but can be made easier by adding a bushing, or piece of water pipe. I tie a single overhand first and test the hitch, if working good I add another.
Now I run 9.3 epicord 28"ers with yale 11.7 forever. I weigh 170. The micho runs flawlessly with little sitback. Cordage when new needs some long fast descents to set itself right. But once it has it's memory intact all it good. 10 AP can fly but prefer 9.3 epi.
Dialed
Niiiiice!
Is that the double eye?
What rope and hitch you using?
Try a 3/1 Michoacan with a 24" 8mm e2e. Amazing for a climber in your weight class.
I have been working with a 3/1 Michoacan now and then when I am feeling comfortable in the climb (broader, lower trees). it has less room to go slack.
a number of hitches lately are making contact with the wrench now and then on its short tether.
I got a batch of hitch cords to tie knots and try out different lengths. I was surprised to find how short I want them to be.
I like this idea to work with the 3/1 some more.
still haven't settled into any ultimate cord/rope combos. like its been said, it depends on the weather; the way I will move in the tree. I love rope.
Not double eye. It is Sumac. A treestuff yale 11.7 from back in the day. That is the original rope logic single tether. Think it was 10.5 inches. Reed does not come here anymore.
Is it safe / good practice to have a single eye on a hitch climber?
Does it not bend the entire system into a strange loading angle?
It's a cool colour the old sumac!
Do you mean rubbing the top of the lips? Only touches there on weightless ascent. As soon as you put weight on it, it rotates counterclockwise (based on photo you posted), so rope is only touching the pulley.
I just found this combo. I can’t believe/what a difference! It’s like getting in a Cadillac after driving some old jalope. Fast descents to milk the 11.7 rope or break in the hitch cord?
That 9.3 epicord on 11.7 is also probably my favorite so far, I have noticed if I’ve been on the rope runner a bunch that my go to hitch tends to creep a bit when I go wrench/hitch system.
Understand this. Happens because of the flattening. I hardly use my runners anymore. But you are correct.
Safe, tried and tested. Works lovely. I used to use a rubber grommet to keep things from sliding around.
I’m contacting all the rope manufacturers to personally make me a rope that won’t do that, it will not callus my hands either! Looks similar to my wrench setup, have you seen arbsessions new variation of wrench tether? Looks promising.
