Great topic into roots of commanding rope to greatest bidding, after a single turn, w/practical; fullest test application..
Still, in ABoK many reference examples of around both parts of each leg of eye circumference/rather than thru close side of each:
That tend to favor tiered series of series of turns
>> w/break between series-es(!)
To my (a)typical modeling; as like air buffer/thermal break in insulation
>>so force not just run 1 continuous degrading gauntlet,
>>but then once devastated faces another, but is softening by self equalizing in between
and even perhaps woven in as shift/creep check!
>>cable 3 or more such spaced grabs typical, in higher friction broader surface, Natural ropes Ashley shows 5 series.
In all my understandings collectively from ABoK shows better to seized in spaced Half Hitch etc. as stopper/final ballast/tailer main in capstan speak, then allow the same stopper construction to (in my terms) 'ram the mainframe/carriage' of the preceding knot to deform from the rear as fight same of not deforming on input. Seems favorable to be a spaced maintainer of the rear part of the knot main carriage shape, not deformer/rammer. Carriage being machine between Standing Part linear input and final tailer man/ballast of Nip etc. The less self contained final size, is more buffered from deforming squareness of carriage from rear aspect. Carriage is also a leveraged friction buffer between the input (load) and output(tailer man/ballast)
ABoK is massive book has unique layout of overly massive subject (to me, as workman that means 'frilly' knots thrown in as distracting bloat
). But opens and closes with generals as builds to specifics in center. Hard not to get caught up in how many can tie as knots flood by, while tying them trying to extract pivotal principles that still carry on into today and further into many things. Folks then were forced to be more in touch with forces more rawly, which few disciplines carry forward so fully as ours.
