The Timberhitch is as safe or unsafe as any other knot or hitch. It needs to be tied properly, dressed and set.
Not so: the hitch is more likely to come untied than other
knots, such as the RB (given that the Bowline is well done,
maybe using a secure extension/version).
The timber hitch also retains 90% of the rope strength, whereas the running bowline retains around 65% ? (going from memory on the RB strength loss, someone correct me if Im wrong). This would be due to less amount of sharp bends in the line.
I don't believe this: they are both, essentially, choker
hitches, and it's at the point of contact with the main line
that the knot will break, IMO.
Ive always thought the TH was the coolest hitch due to its simplicity. I think Im gonna start using it more often.
I think that Ashley's recommendation make a full turn (or
more!) around the mainline before dogging/tucking the end
should be done--this will give a sort of friction grip
on the mainline, should improve strength, and also mitigate
loosening when slack or pulling out on hard loading.
*kN*
I disagree.
*kN*
I disagree.
