ATH
- Findlay, Ohio
I'm guessing the steel forms the softer aluminum so it's a pretty permanent set.I think it's readily apparent how Rigguys stay together, but the Endz seem to be held together by friction alone, which I don't understand. What happens when things get shaken around in the wind? If the two stems don't maintain enough pull on eachother at every moment, I could see that little pin shaking out.
However I also thought galvanized steel and aluminum lead to galvanic corrosion...
