- SE Tennessee
I have been trying to learn a VT hitch for about a week now. I have watched numerous Youtube demos and studied and studied..... I just need to ask a few questions to push me over the top. Seems people have a tough time describing it..... So here are some questions.....
The first part is turns around the rope. I think it is three full wraps but it looks like 4 loops on the side. Some people call it three..... some call it four. The top loop tends to fall down with use. Is that correct? Depending on where the first weave starts it can change the wraps. Should it look like four layers or three from the back side with the first weave on the front side?
Next is the first weave.... should the top wrap come down and lay on top of the bottom wrap or go under the lower wrap in a pinch fashion. I think the pinch fashion is part of the Rich H. XT hitch but just want to make sure.
Next is the second cross or weave...... does the top wrap come down and go around the rope and stay on the outside or snake under the other half of rope and switch?
The last weave/ cross happens just before the pulley.... does it reverse the previous cross or just wrap over like the cross above?
I am using 8mm Bee Line and a 11mm Yale Bandit main line with a Rope Wrench and the ABR stiffy. I have played with hitch cords from 24-30" and the 26" seems about right but I can adjust the tie and get any of them to work. Just seems like the hitch can be tied so many different ways that I am not sure what is right. Maybe some rules of thumb to go by......???? How much friction should be on the hitch on the upward motion? Should it fully release or slightly grab and stay tight? I have tied it both ways......
I have looked at the VT, the XT and the Dos Equis (XXT) but most videos I have seen the VT seems to be the common one. I am trying to keep a good gap between the hitch and the RW so I am leaning toward a 24-26" hitch but need some guidance... Thanks in advance.
Barry
Barry
