Re: Crane Rigging & Knots in Them
Not using a knot in lieu of a splice I believe means that you cannot tie say a bowline and then use that to create a girth hitch. I believe it is in place because that would then limit your capacity an additional say 50%.
I emailed the rigging expert again on this and he said [ QUOTE ]
If the sling has an eye one end and the other end is just a Bitter end, then you would have to put a hitch in it. You must also take your deductions from working load limit for what you are doing. If the sling has a eye each end, you cannot put a knot in it. That would then put you in violation of ASME B30.9 - It says that you cannot make a sling by putting a knot in it.
He is logically concluding what we would all naturally conclude. If one was using a one eyed sling, to tie off loads, then we'd obviously have to use a knot or hitch to pick up that load... He simply stated a fact from an observation. He did not say whether or not we would be in compliance with OSHA or not.
1926.251(d) From the 29 CFR:
Natural rope, and synthetic fiber-
1926.251(d)(1)
General. When using natural or synthetic fiber rope slings, Tables H-15, 16, 17, and 18 shall apply.
And in these tables, OSHA only acknowledges eye and eye or endless slings. --That's it. They do not acknowledge one spliced end and the bitter end abscent of a splice. (I think the tree industry has carried these types of slings over to crane work undetected. Safely, performed, but not compliant).
The whole purpose of this thread is to get to to bottom of how many of us are performing our crane assisted tree removals with great intensions, but are unaware of OSHA's regulations for tieing off loads. Or, in their words, "material handeling."
By no means am I trying to get people to stop tieing off loads with what ever hitch or knot they want to use. Heck, I used to love being able to use a running bowline on the loads to adjust the length of slings.
But, now that I have seen the regulation, I'm changing the way I tie off loads. Simply put.
I had to come to the reality that I may very well get an OSHA audit some day and there isn't one thing I want to do that isn't compliant with OSHA. (In my town, I am the only one who uses a crane on a regular basis. A crane standing 120' in the air gets a lot of attention...)
