Matias
- Silicon Valley
gawddammit guys. I guess I'm getting an Apex.
I agree. I wish I had kept Wrench version 1. I sold it along the way at some point. I have my first Jambo wrench and the 1st ISC I got back from Ben in Australia but the Apex is the ticket. Love it enough to go back to a hitch based system.Thoughts on the apex?
That does sound pretty nice. looking forward to your long term reviewOK, I forgot to comment on a few other interesting changes. The spring on the bird is considerably different. It is fully connected throughout its entire range of motion, meaning it doesn't free float after going over center. Maybe not a big thing in and of itself, but it does hold it still when off the rope instead of flopping all around. It also means that they are using a completely different type of spring. When you press down on the bird, it has a very smooth and linear feel compared to the Pro that gets progressively stronger as it is depressed.
Also, all the openings that are not for rope insertion have been closed off make easier to get rope orientation correct.
The birds beak is no longer open thus reducing potential snags on ropes and smaller carabiners.
Kevin, it wasn't the threads that stripped on my RRP bollard anyway, but the hex insert on the screw itself (my pic above) - both sides! Bart, in post 47 above, discusses the different shapes of screw heads - in my mind, even with the replacement bollard/ 2 screws I bought from TreeStuff, the round head of the screw could probably be much more, well, "roundy" giving a deeper machined hex section to give grip on with a well machined solid hex key. But I also think better steel for the screws woulda been a good design upgrade. The threads are fine, even with the blue goop they come with (threadlocker). All this is probably academic anyway now the new model RR is out.The hex key that comes with the pro should NOT be used. That was a bad idea. Clearly.
All threads that I have ever encountered are capable of stripping. My old neighbor taught me a trick that I was grateful to learn. If you spin the bolt backwards first, when the threads line up right, you will feel a click, then it's safe to turn the other way to tighten. you all probably knew that, but that trick has saved me a lot of heartache.
I love the Notch rope wrench. So simple, so easy. If you have trouble with being a light climber the notch wrench is the only one that opens up wide enough to be a light climber on stiffer rope. On other adjustable wrenches, I could hardly find any meaningful difference in the adjustments.
Prob zero difference.Anyone know what, if any difference is there between the CE stamped and non-stamped versions of the Apex? They are the same price, so why aren't they all stamped for simplicity's sake?
Freexion by Fiori has another construction and dont need stiff tether at all,this device will stand on the rope if you pull it up/inside we have cam with springI started climbing start of 2019, and have never climbed with a floppy tether, but I am curious. Anything specific I should know? Warnings?
It can happen only with RW not frexion due to constructionGolden oldie explaining floppy tether snagging RW and pushing hitch down. IIRC this is what took Cary Gibson for a ride.
