The Icetail ring Prusik could be redone with shorter buries to make it longer. The tails don't have to overlap to be safe, only to give a consistent diameter to the cord, which some hitches need, but the Prusik doesn't. Locked brummels are possible on both eyes by unbraiding, and rebraiding, the second tail.
Oh really? No kidding.. i didn't know this.. does that ring true for all prusik's?
So.. if you look at the last post with the Ice Tail you'll see that they don't over lap anymore.. & the cordage is fairly even.. at least when i put it back together for the second time i thought it was. However, I'm pretty sure that i thinned out alot of it starting pretty low.. i think i took each side down to 6 strands & then the total bury is about a fid..
Stay tuned. I'm going to go take a look at it right now.. so i may add to this post
Ok.. so im not sure if i cut anymore off of the taper lengthwise.. i may have buried thinned back further towards the beginning of the bury as best i could.. (hard to keep track of which one your cutting when there's already a taper in place)..
This is what it looks like before..
This is what i had after pulling apart first time
This is it after i tapered & right before second burial. If anything the left side is just a little thicker & was still a smidge longer after burying.
This is it now..
it's alot thinner & i gained some length back..
Not even as close to as stiff as it was before.. before
Now.. flexes under own weight.
Now because your saying i can still use this thing, I'm going to pull the bury again & take a peek at how the taper looks. I'll post up but i think they will be the same as the third picture.. Now, once I'm in there your suggesting i should just even things out if i haven't already? The uneveness is your concern?
Now that I'm looking at it again, I think the width is pretty even, Im concerned your suggesting is based off of pictures you haven't seen yet & possibly what it looked like after the original bury.. i just can't see right now whether i posted the second bury yesterday in my previous replies.. I just don't want to take too much out seeing as original instructions were asking for a 8in X-over & two locked brummels. Right now i got a pretty thin fid length missing 6 strands half way into it.
Take a look at these newer second bury pics above & let me know if you still feel the same..
Also, i don't know how to disassemble & braid . Haven't tackled that yet.
