1. I have LOTS of Tulips; they are very prone to storm wind breakage.Tulip Poplars are some of the biggest trees in my area and can be very fun to climb due to their branch structure. As others have said the wood is fairly brittle so I use larger tie in points and attach most high canopy anchors around trunk not just a limb. Forest grown tulips can get well over 125' high in Ohio and the Appalachian foothills. I've seen some of these straight as an arrow tulip towers with the first branch around 60' and other healthy specimens that have snapped of half way which be concerning.
Firewood heat / BTU is basically proportional to dry wood weight. (not volume, cords, etc)Makes nice looking fires, big bright flame. Not alot of heat though.
You can lanyard in, and move your SRT device over the crotch in front of you, or advance the tail higher. Lock the SRT device on the rope so it will hop over, not slide at the crotch, so then return back to you.
Be prepared for some tangling issues and a way to manage them. I'd suggest that you consider the most amount of throwline that you may need in the canopy, add about 10' just incase, and only take that much with you. It'll be easier to manage than your long throwline for on the ground.Awesome - I've not really used throw line above ground yet!
Tie the throwline on to the Canopy Anchor loop, before sending it up.Awesome - I've not really used throw line above ground yet! I'm spending some time trying to work advancing, converting, etc., out on paper before taking it to the tree.
So I'm leaning towards attempting setting a canopy anchor around the stem from the ground, running it up, then clipping a throw line in once I reach it, for retrieval. Wish me luck.
If something doesn't work, or look right, you can pull it out & start over.
