- Retired in Minneapolis
The anchor system for SRT is an evolving process. The system that I'm using now is quite simple and has a long history in arborculture. The belaying friction is developed by wrapping the rope around the trunk as many times as the climber feels is needed.
After the wraps are made a friction hitch FH is tied around the rope and then clipped off 'uphill' from the hitch. If a rescue lower is needed the groundie/rescuer would grab the FH and let the climber slide down. Since the FH is never untied it is a backup belay allowing the rescuer to move around if needed.
In the pics you'll see the black cord tied around the orange climbing rope using a Klemheist. This is fast becoming the preferred FH for this application replacing a prusik. The FH can be backed up again using another HMS biner and a clove hitch. I'm going to get pics of this setup tomorrow.
When the first spiral is run down the tree keep it quite vertical. Then at about 2/3 wrap start to flatten out the round turn on the trunk. End with the rope parallel to the ground with at least one full trunk wrap. My preference is to use 1.5 wraps or more.
When I was at Expo Octavius made up a eye/eye cord out of Icetail to have a high friction hitch. One end has a large eye for the Klemheist the other is small to keep it snug on the Mongoose.
