moss
- Carlisle, Massachusetts, U.S.
Having strained tendons on both forearms and also messed up a shoulder, what worked for me is to keep climbing but make gear and technique modifications to allow the injured areas to take much less load and have a chance to recover.
For example my left shoulder was toast for most of last year. The solution was to climb SRT with a chest roller. The effect was similar to what the Croll does for you (as Chris described) except even better. It was very easy to climb one-armed, the chest roller allows you to use your legs and core for primary ascent power. I used my good arm to move an ascender w/footloop up above the chest roller. The bad arm had a free ride and got to do simple things like help tie hitches and fiddle with gear ;-)
Question is, can a RW or HH be installed on the rope at the same time as a chest roller? One approach would be use the chest roller for ascent only, switch over to the RW once you're ready to maneuver in the crown. Hitch can stay on the rope the entire time below the chest roller if you rig it all low enough.
