rfwoodvt
- This side of eternity.
Anyone using the plunge method of aeration with their airtool?
I tried it yesterday, just mucking around, and was please with the speed and depth. Only problem is the very large diameter hole left behind. I'm used to using a 2 inch auger which leaves a clean hole that doesn't require filling.
I've always prefered NOT filling in the voids because of the thaw/freeze fracturing that loosens the entire rootzone over the following seasons.
If you do bore, or radial trench with an air tool, how do you handle the resulting voids from a client safety and mowing perspective? Or, do you even worry?
