It's a 7k rated trailer with 5k payload, pretty close to max payload loaded and chained down. ~3500lbs MT100, 1100lbs shredder, 4 3/8's inch chains 20ft long each with 4 binders.What's the weight of your trailer set up like that?
--checking 'tuppence' off of my "non-'merican" English Bingo card--Those Eliet shredders are popular here, I’ve seen a few in action.
I wouldn’t give you tuppence for one compared to a disc chipper.
If you wanted a Euro chipper and wanted what would suit you best there is probably years of info stored up on threads on the Euro Arb Forum. Forget the name of that one - suspect Mick could tell us.I am moving to N.Idaho/CDA And I’m considering adding a small 8” tracked chipper to the fleet in a year or two. Debating between the TW 280VGTR or a Jensen Spider A550XL with winches.
I would have a Timberwolf/Morbark dealer local, but the UK forums seem to point to Jensen being supreme.
I feel like it would these incredible on some of the lakeside and hilly terrain as far as getting rid of brush, and serve as a low production back up chipper if our 15XP went down. We could track it into people’s yard and just leave mulch there!
Most of the trees are pine, fur, spruce, which is really soft wood, especially compared to here in Oklahoma where it’s primarily oak and hickory. Even these hundred foot conifers trees have pretty small diameter lower branches.
Besides an opinion, between those two chippers, does anyone know how many hours you can get out of one? Obviously it depends on maintenance and how hard you push it, but assume it’s pushed to 80% of it’s limits daily with perfect maintenance.
Arbtalk Merle.If you wanted a Euro chipper and wanted what would suit you best there is probably years of info stored up on threads on the Euro Arb Forum. Forget the name of that one - suspect Mick could tell us.
I sometimes drop in an Ye olde Englande word in, just to keep you on your toes!--checking 'tuppence' off of my "non-'merican" English Bingo card--
(had to look that one up...I "hear" it now that I know its "two pence", but didn't know it before)
Good points. Actually it occurred to me after my post I would consider your thoughts to be top notch if I were looking for a light weight chipper and would only use Arbtalk to catch any other points about that class of chippers that I hadn't thought of. I researched chippers for over a year before I had Bandit build one for me with a bunch of options. And I learned so much in that time and ended up with a machine I love that saves me time and effort in so many ways over a stock chipper off the lot.Arbtalk Merle.
In fairness to the op, he’s looking at a choice of three, and like all of these threads, there’s a lot of people with a certain brand, who will recommend what they have for various reasons.
I had a terrible experience with Först, but others like them.
Like everything, a lot depends on support and if you can work with your local dealer.
Merle, can you enlighten us as to what machine and custom options you got?Good points. Actually it occurred to me after my post I would consider your thoughts to be top notch if I were looking for a light weight chipper and would only use Arbtalk to catch any other points about that class of chippers that I hadn't thought of. I researched chippers for over a year before I had Bandit build one for me with a bunch of options. And I learned so much in that time and ended up with a machine I love that saves me time and effort in so many ways over a stock chipper off the lot.
I’m sure, they make PTO driven chippers. Seen some on unimogs and tractors. A stout hydraulic motor running a belt drive if the right ratio could probably power one.I wonder if it’s possible to make a mini chipper attachment for a mini at a reasonable cost? Cannibalize a small Bandit or, god forbid, a Vermeer.
Salsco has PTO chippers:I’m sure, they make PTO driven chippers. Seen some on unimogs and tractors. A stout hydraulic motor running a belt drive if the right ratio could probably power one.
(I've wondered if it would be possible to mount one on a truck between the cab and a dump box on the back...but not wondered enough to really look into it)
So I'm not nuts! It actually exists...Chipper/Dump Combo Trailer
I just finished getting this road ready. It is by NO means done, since I really want to paint it up nice and hopefully have all the little details ironed out by then. I focus on pruning, so this will work well for me. I totally realize it's not everyone's cup of tea, but it always made sense to...www.treebuzz.com
Click on the ‘chipper/dump’ link I put above and check out the second post in this thread. Your idea holds water…and chips!
