Daniel . Ok I'll bite.
Wtf are you using the center plunge in an urban setting? The center plunge removes holding power of the hinge. As a professional logger I would never use that technique in the urban setting for fear of losing control of the stem. I've had so many trees "pop" those corner posts and go 90 degrees to my desired lay. A bit of decay, included bark, seams, twisted grain can fail so easily its scary.
In the woods that cut is used to prevent fiber pull, splitting and barber chairing also its major use is to weaken the hinge so that if the tree contacts other trees on the way down it can roll off the stump. By leaving 2 small "posts" on either edge of the face it still provides just enough directional control to keep the tree on its desired path, but not enough to prevent it rolling when needed. Veneer cutters have used it for decades, also use it when your bar isn't big enough to reach your center wood if big stem.
I'm not on the ground to see you do what yer doin but it seems like you are rolling the dice with that technique. And claiming like u invented it. Wait til you have a post pop on you and you will poop yer pants.
I appreciate all your vids etc but this center plunge has no space around targets. My 2 cents.
Good to hear from you... It's been a long time... Hope you've been well..
The center plunge is my preferred cut to use on anything big. Even when obstacles are of great value. In other words I trust the hinges that result from center plunging more than a full hinge. The one difference between my scenarios and yours (you don't trust the center plunge) is that I AM pulling with heavy equipment and a high pull line. I would bet the times you have lost your trees to side weight, you were using wedges, not ropes.
I would never attempt to fall a tree around valuable obstacles without a high pull line. I see these YT video of guys banging wedges with no pull line on trees that have been topped. That's crazy IMO. You were there to make the cut.. Why not put a line or two in there while you're at it???
For clarity, I disagree with your second sentence as follows:
When used properly, the center plunge adds strength to the hinge. I have never lost a tree with a center plunge hinge. You might have to cut your hinges down to 2-3" thickness before you can get the tree moving with wedges. My hinge posts are 6, or 8, or 10" thick, when needed. I AM usually pulling with a 10,000 lb loader that has 4x4 and wide tires. They aren't going to pop...
The biggest bar I have been running in the last few years is a 28. Right now I think all the saws are 24s. So I'll use it often just to make short bar falling cuts easier.
And what makes you say I "
I made no such claim... EVER... What you might be hearing in my tone is just excitement. I love the cut and as said above, now use it all the time... I particularly like to use it on backleaners and with the tapered hinge on side leaners.
I know I have been using it since 2004 because the first time I ever used the cut just so happened to make the cover of the July 04 issue of TCIA magazine. That may actually be the first time the technique was published. But I didn't know what I was doing with it back then. I only used it because my mentor, who took the picture, told me to use it on that back leaner. It's only been the last 5 years or so that I have become much more experienced with its use. I AM a huge fan of the technique. The fact that your post, critical of the technique, got so many likes shows that, once again, I attract controversy.
SO before anyone else gets started: I don't care who you are or what kind of credentials you have. There's nothing you could say or do that's going to change my mind. I trust the cut because I have used it extensively and know what it can do. There are of course some contingencies, but that's for another comment.
