data farm 26
Been here a while
- the raft
Whats the draw to a 9mm bone? For use with captain hook or similar?
I’m interested in a twin 8mm rig.Whats the draw to a 9mm bone? For use with captain hook or similar?
I had a rec climb yesterday using two systems that got me thinking about TRT again as well but have yet to experiment. Logistical nightmare in a short wide silver maple - would have loved to be able to manipulate two lines from the same point of friction like I’ve seen on some of woodenhand’s stuff. Casting my vote for a twin8 bone!This 9mm conversion could be used with a hook line. The 9mm bollard looks weighty in the picture, but since it is made with 7075 aluminum it is only 1/2 ounce.
I'll have to think about a twin 8mm.
Would love both on one side for easy one handed descent/positioning and whatnot but I also have not done anything with twin ropes anyway. it sure is neat! Seems way specialty but would love to see something like that availableThe twin device pictured is a proof of concept (I called it the Crab in an earlier thread). My thought was you could use it with a pulley above and a foot ascender on either foot. It works in that manner as one side ascends then the other.
However it seems good also for a twin line configuration, when you might have two separate lines coming in from different angles, say for work positioning. Or you could use it as SRT allowing the rope to be retrieved like you would a a double line.
I remember that, and I like it, but the 180 opposed layout is my initial hesitation. If they were side by side I could jump on board!@oceans How important would midline capability be. This one works with the tendril (each side works independent of the other) and might be modified to work with twin 8mm.View attachment 95018
... My only challenge with this setup is that it is very fiddly switching the BD back to stock to run on other rope diameters. This process while aloft has lots of exposure for dropping small critical metal parts and requires pliers/tools...
