rope-a-dope
- Asheville
I like that! Quickie and butterfly is my #1 anchor. Working down a spar in long sections you can just tie another butterfly for the quickie instead of taking all the slack out
That's clever. I will try to remember it when the time comes.I like that! Quickie and butterfly is my #1 anchor. Working down a spar in long sections you can just tie another butterfly for the quickie instead of taking all the slack out
That sounds pretty decent, and it gets your hitch closer to the end of the line so you can just pop it off the end when you hit the ground.I think the point is to tie another midline-alpine butterfly, leaving a long tail on the working end, rather than moving your hitch to the top of the working end to choke the spar again.
If you lower down after taking a top off, dropping 20' for a 20' log, you can pull your choked AB down, and rather than moving 20' through the hitch, you tie your second AB 25' from the end. This will let you have fall-arrest if on a spar with a flipline (180 degree wrap) and spurs, if you set a second TIP before retrieving your first TIP.
Homemade friction saver. 2' strap, tri-lock carabiner, figure 8 all attached with girth hitches. All together about half the cost of a Buckingham model, and made from parts you may already have!
I've done that before and it didn't really work the way you expected. The biner and sling slides down or up the rope depending on how the balance on the piece is and behaves much more like a running bowline with a half hitch above it, than like a spider leg.When rigging from two separate points, you can tie a Blake’s hitch with one line to the other. This way you only have to tie one leg each time, and the ground crew only unties one. Slide the Blake’s to gain enough tail to tie with, then slide it back down to the knot. I’ve used this with a grcs on the Blake’s side and no slipping.
Something I’ve not tried, but that came to me while sharing this- to get one rope in a different place on the piece for better manipulation but still avoiding a lot of tying and untying, incorporating a sling and biner could work by choking the sling where you want the load, and clip the desired leg into the biner. A little more gear, but still a lot less tying. If I don’t get to it first, someone try this and let me know. In this scenario, I would tie the Blake’s to pull downward toward the knot, so that loading would pull it toward the knot rather than away. Normally, I tie it so the tying tail is exiting the top of the hitch, but I’m not sure how things might change, if at all, with the deflection of the sling and biner.
Different things, yours should work as you drew it. I was assuming only 1 line.I’m wondering if we’re describing the same thing. My goal is not to spider leg. The initial idea, which was pictured, just puts two ropes on a piece when using two rigging points, whether it be a rigging point in another tree with a brake line in the tree you’re climbing, or rigging a “y” to it a drop zone between stems.
The second idea (which may be the one you’re referencing?) was to redirect one of the lines down a branch, so that one is simulating a tip tie in addition to the butt tie. I’m not attempting a spider leg. In general, they tend to be more work and too involved when smaller pieces works just fine (my opinion).
Here’s a quick attempt at illustrating my thought to see if we’re talking about the same thing.
That's the last time I had seen one Jaco CRStreet vendor San Jose Costa Rica
