Jehinten
- Evansville
Thanks for your reply. I am a newbie with ropes and tree climbing. I have had my saddle for a couple months but have not been using it everyday just an occasional practice session. I did purchase a device to make the bridge adjustable and i did notice with it being longer it is a bit easier to sit more upright. Lol, you may have hit the nail on the head with core strength! I am a bigger top heavy built guy and I know that is not helping my situation but I didn't think I was in that bad of shape!
I am pretty top heavy myself and I don't find myself falling backwards, although it did take a while to get my harness adjusted so that it was comfortable. Several adjustments will change how you sit in the harness and how it feels. In addition to the adjustments listed above, if you wear the back pads lower, you will tend to lean back more than if the back support is higher. Try making a few adjustments, even to the extreme just to see how it effects your positioning. Then you can find a happy medium between where you are, and the extreme adjustment that moved you in the right direction.
All that being said, how you wear your saddle will really only help when your not ascending. If your having trouble while ascending that is either a technique issue or perhaps missing a vital piece of climbing gear. Give us a little more info on how your climbing and what tools your using and we can try to help get you on the right track.
