Monkey Beaver harness
Thanks for your reply. I am a newbie with ropes and tree climbing. I have had my saddle for a couple months but have not been using it everyday just an occasional practice session. I did purchase a device to make the bridge adjustable and i did notice with it being longer it is a bit easier to sit more upright. Lol, you may have hit the nail on the head with core strength! I am a bigger top heavy built guy and I know that is not helping my situation but I didn't think I was in that bad of shape!
I am pretty top heavy myself and I don't find myself falling backwards, although it did take a while to get my harness adjusted so that it was comfortable. Several adjustments will change how you sit in the harness and how it feels. In addition to the adjustments listed above, if you wear the back pads lower, you will tend to lean back more than if the back support is higher. Try making a few adjustments, even to the extreme just to see how it effects your positioning. Then you can find a happy medium between where you are, and the extreme adjustment that moved you in the right direction.
All that being said, how you wear your saddle will really only help when your not ascending. If your having trouble while ascending that is either a technique issue or perhaps missing a vital piece of climbing gear. Give us a little more info on how your climbing and what tools your using and we can try to help get you on the right track.
Are you talking about ascending the rope or just relaxing in your saddle? Also, double rope or single rope? Nice recreation saddle by the way ;-)
If you are falling back while relaxing then your bridge might be too short or your leg straps too short. When both are short, it keeps your connection point and center of gravity near your naval. If you are top heavy, you'll fall away from your connection point.
Also, tree saddles are designed to craddle you like a baby when you are connected to the bridge and dangling suspended. You are supposed to fall back so that you can relax you arms and legs - like being in a reclining chair. Very different from pole climbing.
When you are vertical and in the tree, the side D's are used for hip support while you legs are holding you up for support - the more pole climber position as you are using your lanyard to go around a limb or spar.
When are ascending, if you don't have adequate upper body strength, focus on keeping you weight over your ankles by looking at your feet, and hands by your naval or armpits. It will train you to use your legs and not your arms as well as leaning forward for balance. Every time you look up, you'll lean back.
Sent from my SM-N950U using Tapatalk
I appreciate your reply!
While just sitting in the saddle I feel as if I am going to fall over backwards so I am constantly holding onto the rope. I have an adjustable bridge and have been playing with the length and helps a bit. I have been adjusting the leg straps trying to find a happy medium. Perhaps I need to tinker with it more often! Or perhaps I am not used to a saddle, as it is totally different than my old pole climbing belt. So its normal in a saddle to be leaning away from the rope and not sitting straight upright? You'll have to forgive me but again I am a newbie in a saddle!
I have tried double rope and single rope. I can hip thrust on double rope and get up the tree but that's a whole lot of work. I added a foot ascender and a hand ascender with a foot loop and try to go up the rope and get maybe 20 feet and my arms get spent. I attributed that to not being in line with the rope on the ascent as my an feet usually kick out to the front so i am pulling with my arms more. After reading your reply I see that I need to learn to keep my feet under me and my body in closer to the rope. Like most things that people make look easy, it's about technique and practice! I am going to try your suggestions and do some more practicing. I sure appreciate your help!
Yes - when just "sitting" in the saddle, you should be leaning back like you are sitting in a reclining chair and shouldn't need to hold the rope to remain comfortable or with no more effort than you'd hold a fishing pole.
The only time you should be vertical or upright is when all weight is on your feet - ie, in the tree or ascending with foot ascenders.
No worries about being a newbie - we all started in the same place and it took a while until we were comfortable.
In fact, I hate working a spar and prefer to dangle and prune.
I am definitely going to move things around so that I can at least sit comfortably while suspended without constantly holding onto the rope.
I have several issues going on. Ascending on the rope is going to need much more practice! After reading the replies from you and Norcal, I can understand why I am having the issues staying in line with my feet under me. There is much more technique to this game than I thought. I believe i am all out of whack and I end up pulling more with my arms than my legs!
I have been reading these forums for awhile gleaning info but never posted, sure glad I did. Thanks so much for the help!
A lot is learning when to relax certain muscles while using others and trust the gear - it'll come with time and practice.
I may have missed a few words here and there and have to get off my phone now but I'll bet when you are climbing well and enjoying yourself, 39Buick, you will look back and say it was 90% technique missing (and adjustments) and 10% or less about the shape you're in.
Climbing a rope well done by someone with great form (not me) is so much legs that hands only barely touch the rope for balance. Youtube vids of some good SRT climbers for form. Foot ascender, and another ascender on the other foot but it has a short section that takes it up to about knee level. (Knee ascender.) Short - like 8 inch steps up. Like baby steps marching up the rope.
Welcome to TreeBuzz by the way.
Hey Guys,
I am needing a bit of help. I am a new older outta shape ex pole climbing guy trying to climb these tiny little ropes you guys swing around on for a living! Hats off to each and everyone of you!
I have purchased the Monkey Beaver saddle and other gear from treestuff to climb some trees for recreational purposes and to maybe do some limbing and trimming on my property. The problem I am having is staying vertical to my climbing line. Would it have anything to do with the way i am wearing my saddle? While sitting in the saddle on rope i am falling away from the rope. I can not get it adjusted so that i can actually sit straight in it. I tried and quickly discovered that the little inexpensive weaver chest harness was not going to help! Would rather get kicked in the nads before trying that thing again. I have been able to go up and down maybe 20 feet or so but that's about as far as I can go before my arms feel like they are going to give out from holding myself up all the time. Any suggestions sure would be appreciated. And Thanks for your time.
Hey, @39Buick! Welcome to the TreeBuzz forum! I'm just curious about what your specific complaint is with the Weaver chest harness? Does it pull hard against your ribs in the back, painfully so?
I had and probably still have the same issue you are having, and I thought about it and made my own chest harness out of webbing straps, with the addition of one more that attaches to the horizontal strap in the back, but comes up and over my shoulder on a diagonal, and ends with a pulley attached that stops just past the front of my chest, but up high. I attach the pulley to the rope, and it holds me upright, like the webbed back of a lawn chair. Someone created an illustration of it that looked nicer than what I made. Probably @Brocky. I need to search for the thread and find it, but right now I need to get to bed.
Also, do a search for the discontinued Rock Exotica chest roller.
Tim
P.S. Here's a link to a video of a 1st time user of the chest roller. Expensive, but it sure makes it look a lot easier.
it was the length of the straps at the back of the leg loops - at least in my case 39Buick,
once I dialed the (what I refer to as the butt straps) length then I could make the adjustments to the other parts of the harness and that feeling of falling backwards all the time went away.
sure felt weird though the first couple of days till I had got the the nub of the problem .
Thanks Tim.
Painfully Hard! I don't think that particular chest harness was designed for the same use as the one in the video that you shared!
The chest roller and harness may be the trick to help me learn on, kinda like training wheels! I have found a source to get the harness and roller plate but didn't want to fork out the $200 bucks if I really didn't need to. Also didn't want to waste those funds if it really wasn't going to help or if it were just as painful as that little weaver harness!! All these youtube videos of folks climbing make it look so easy, I have a lot to learn!! Thanks again for your help!
Thanks Merle! I am sure your right and will be glad if I can look back and confirm your 90/10 analogy!
Thanks for sharing! I have yet to find that sweet spot, hoping to get into it this morning and try some different positions. I watched the videos that August put on youtube and read the instructions and have moved straps around some just have not got it just right yet. They all say that you have to get it "dialed in" and i'm like:wtf: exactly is "dialed in" . This is my very first suspension type harness so excuse my ignorance but I don't know what dialed in feels like! I am learning though thanks to the great feedback I have gotten here thus far!
For pics of how you should be able to sit at rest, check out crane climbers riding the ball and recreation climbers. Most working climbing pics will be of ascent or lanyard into wood.
I believe there are a couple of videos showcasing how to set up knee ascenders where they will freehang from their rope while setting up the ascender.
It may help to see what position other climbers hang in, at rest. Hopefully that will help you find your own “dialed in”
@39Buick don’t worry about your ascents until you get your harness adjusted. That way once your in the air you can be comfortable. But when you do get to that point, if you mimic the action of backpedaling on a bike while climbing it will help keep your feet in-line and under your body. That takes a lot of the work out of your arms.
Great advice!! Thanks again for your help!!
With regard to that chest roller and $200 expenditure, if climbing the way you want is beyond that and that is just training wheels - don't be tempted. Training wheels are too short lived.
To continue the analogy I love the new kids first bike with no peddles and close to the ground. (Gliders ?) A kid will sit on the bike and push himself along with his feet. Well, one day that won't be fun enough and he/she will lift their feet. Presto - they just got 'balance.' Gone is the trama of mom or dad tricking a kid that they will still be holding on.
You're only minutes, or hours at most, of practice away from getting a functioning style that will work well for you 39Buick.
Hey Guys,
This is probably a common problem for us older guys who get a bit top heavy when we hit middle age. I had the exact same issues when I started to rec climb, had to struggle to sit upright and got exhausted very quickly from the effort.. I can only tell you how I solved it. My current set up, either single or double rope, is with a SAKA (HAAS would also do) and a foot ascender so I don't have to put much strain on my arms. Then to stay upright, I bought a PMI chest roller and the neat chest harness that goes with it. I can climb almost hands-free with this arrangement, like climbing a ladder. When I get aloft, I can quickly unclip my line from the chest roller for moving around and limb walking. I have the double chest roller, which handles two lines, side by side, so it works with double rope too. What I do there, when on DdRT, is to float the hitch or mechanical up higher with the standing part of the line through the eye on my bridge and back up to the device, with a prussik on the standing part to advance the hitch or device. By moving the prussik up or down on the standing part, I can adjust the height of the hitch or device. Both parts of the line are thru the chest roller so I stay nice and upright just as when on SRT with the same setup. Hope this helps.
That sounds about right!! Thanks for your very much appreciated input!! I spent about 3 hours yesterday playing with the adjustments on my MB saddle and although it is not dialed in as they say, I have made improvements and can at least hang without holding the rope and tipping over backwards! Now maybe just some fine tuning and I can move onto climbing!!
@39Buick; Could you tell us what adjustments you made to the setup of your Monkey Beaver saddle that now allow you to sit without needing to hold onto the rope? I think this problem is a common one, and any hints you can give will help others who experience a similar circumstance. Thanks.
Tim
@39Buick; Could you tell us what adjustments you made to the setup of your Monkey Beaver saddle that now allow you to sit without needing to hold onto the rope? . . .
Yes, would love to hear what you did. I had an idea also, from my other post. I think you can buy the nice PMI chest harness itself separately. It has a wide pad in back and is a lot more comfortable than simple webbing. The harness itself is a lot less expensive than the roller and I think it could be used somehow with just a biner around your line. Not as elegant as with the roller but would still keep you upright, especially when you just want to sit there and rest a bit. I haven't tried this but I could take my harness without the roller and see how that works, if you like. As others have said, however, it is such an individual thing. There are as many climbing setups as there are climbers! And you may have solved your problem already with the adjustments you made to the Monkey Beaver. I am saving up for one of those myself but have already spent so much on rope and gear every time I walk into WesSpur that I have had to rein myself in rather severely! LOL. Anyway, best of luck! Spring is almost on us!
Tim
I don't know why I didn't think of that!! I actually made the adjustments to the butt straps to get those more comfortable while in the harness. The biggest adjustment was made to the rigging plates. The length between the attachment point on the waist belt and the rigging plate has about 6 to 8 inches of movement. On New Tribes web site under the Onyx tab there was a users guide that showed in detail each part of the Onyx saddle. I did not find as much info under the MB saddle tab. at any rate, the "Bridge Strap Adjustment" changes your center of gravity as you sit suspended in the saddle. When I started my adjustments mine were fully extended. As I shortened that length it seemed to bring me more vertically towards the rope and a much more relaxing feel as I could hang in the saddle without holding the rope and not fall over backwards!! I still need to tweek mine some more but my my my what a difference that made. I also may have discovered a small design flaw in the belt. On the left side as i brought that adjustment in and weighted the saddle the rigging plate started to interfere with the waist belt buckle. I don't no if it would ever cuase the buckle to come loose but the fact that it actually got bound up in the buckle caused me to lengthen that strap. I don't really know enough about these products to say that it would be a design issue so take it for what its worth. I personally did not like the metal on metal contact and binding of these two components. It does state in the documentation to make small adjustments and I did find that to be true. One would not think that 1/2 of an inch would change much but it really does!! I am thinking to really get this saddle dialed in one would need to make small adjustments to the saddle and then climb/hang on it until you get it to the most comfortable spot. And one more thing, as you move your adjustable bridge in and out the feel changes as well.
Didn't mean to go on and on with this reply so in summary " Bridge Strap Adjustment" would be the place to start!!
I take that back, start at Treebuzz and ask dumb questions and the Great folks on here will get you headed in the right direction. You guys are amazing, thanks for the help!!
Always hip to lower D ( or rigging plate ) is the adjustment for suspension...rope bridge length is moot....I run a short bridge on my TM and when suspended I sit in perfect balance....no leg numbing etc...total comfort...you should be in neutral when suspended...not falling foward or backward....
