monkeylove
- Roslyn, Pa.
Okay so maybe not bottle jack. I need to look into this one. Here are some pics from different angles of what it looks like. It might be hoist from above only.
View attachment 42646 View attachment 42647 View attachment 42648
When I was looking down at Rick's he had some like that and showed me them and how they worked but this one appears void of the connections needed. One of the Bandit vids I watched showed the mechanic using a hoist to raise it up. Monday I am going to eye your system up. I doesn't look all that complicated to fab the upper holder and add a cylinder. If I do that I will probably just add the valves for a future winch. I'm told the hydraulic Mile Markers work great and are less then $1,500 to buy.
Forgot the springs Mert. Long eye bolts with nuts that are easy to adjust. In fact I need to write that dimension down so after I remove them I can reassemble them with the same tension.
@AxeTree I believe has added a lift/crush cylinder to a Bandit. If you can find a salvage unit you can rape the parts from that. Including the winch. Be weary of Mile Marker. They used to be my favorite years ago. In more recent years I've learned they are made in China. Buy quality ..... once. Even a used winch that needs a new line and tlc. Good luck.When I was looking down at Rick's he had some like that and showed me them and how they worked but this one appears void of the connections needed. One of the Bandit vids I watched showed the mechanic using a hoist to raise it up. Monday I am going to eye your system up. I doesn't look all that complicated to fab the upper holder and add a cylinder. If I do that I will probably just add the valves for a future winch. I'm told the hydraulic Mile Markers work great and are less then $1,500 to buy.
I don't think valves are that expensive. Just make sure you get a motor spool for the lift cylinder and and a cylinder spool for the winch motor. Sounds backwards but we use them differently than most.Shoot swings 360 but I would have to try that method out. Thanks Royce.
The valves aren't cheap for sure but plumbing them in doesn't bother me. It really just comes down to the design and flow patterns you want to have when you're all done. Thanks Mert.
Paint mark or piece of tape on the eyebolt before loosening.Forgot the springs Mert. Long eye bolts with nuts that are easy to adjust. In fact I need to write that dimension down so after I remove them I can reassemble them with the same tension.
