Only, inline is not leveraged i think. By taking any angled/ non-linear route; we are taking more distance to carry the load; to do the same work.
Only force can overcome distance, thereby; anytime distance is altered on one side of the balance; force on the other side of the equation must be adjusted.
i think that the Clock, actually has 4 legs of support. But, if we plot a line from the initiating pull force on the Porty etc. straight ahead ; we will find each of these legs of support to be angled from that inline calculation of the force on the Porty(etc.).
A pendulumn will hang theoretically straight down as the minimal force position. If we pull across on the load/ weight, to make pendulumn hang at angle; we must extend the line to make the weight reach just as far down from it's support - In the Direction of Gravity (not calculating the distance of line as work done direction, looking at the direction of force flow to how far down/ not over). So, that, the angled line now takes a longer route, carrying the same load, to reach just as far down. This is just like, using a longer lever of distance travel, with same pressure down on it; it creates more force in trade for the extra distance, to do the same work of flow with the force. Inline is the shortest distance, minimal loading; all non-inline paths take a longer leveraged route.
If the teepee / partyhat of Clock is more pointed/ less blunt, then the loading can become safer, but less grip on host spar; especially noticeable on pulls pairallell with the spar; that more severely test the grip of hitches.
All this inline force, is also part of why on the hitches to secure, i recomend bitters seat at 6o'clock to the initiating pull on Porty; then specializing that so, that most hitches would have bitters trapped at 7 o'clock to be almost as inline pressure, only off to the side. So that the bitters would have to pull up the hill to 6o'clock and firmer pressure (if trapped at 6o'clock could more easily travel 'down the hill' to less pressure). Except for backhand hitches that reverse; then their bitters should trap at 5 o'clock. Taking clockwise wraps to initiate, Porty as 12 o'clock in all examples, any trappings of bitters or tail to bitters best at convex locations. Looking at intiiating force (Porty) pulling away from spar most, and backside seating into spar the most (to trap bitters best). Side pressures being inbetween.
At least in my 'book'....
