Crimsonking
Been here a while
I’m with you, Moss. I’ve talked with manufacturers who have said that there is some loss of strength due to bend radius, but not enough to warrant fear of failure. The other interest I’ve had is the difference between xstatic and drenaline. According to Rob’s argument, it would seem that the wider drenaline would need a larger bend radius than its slightly smaller counterpart, but we know that drenaline is considered ddrt compatible.I looked around for the 8:1 sheave diameter recommendation for KMIII but couldn't find anything. Probably didn't try hard enough ;-) It's all about the core not the cover for a static kernmantle so this is about the nylon core and construction right? Curious to know more, is it about the Nylon or is is about the core construction and the Nylon? Very interesting.
From my understanding, the greatest issue/argument against static lines as ddrt lines is reduced elongation when doubled. The funny thing is, there are double braids out there that have less elongation than some “static” kernmantles. The only thing left to explore, in my mind, is the reaction of the core fibers to a dynamic load while doubled over a sheave/rings. Perhaps the parallel fibers are somehow more prone to failure? Inquiring minds want to know!
