the xman: yes your drawing and comments are accurate now after that I simply boom down and hack it up into bits worked well with my new rope and added skill set
Okay, thanks, wow.
Your new rope worked today and your better knot tying helped too probably.
BUT it won't work for long.... and that's why I'm glad we are continuing to talk.
This is pretty much the worse abuse you can do to your rope and pretty much any reasonable size rope is NOT going to endure this technique for very long.
I take big stuff (I think) in my rigging, but it is to speed up our day; but we do it safe and very, very rarely, would I allow a short section of rope to catch a dropping weight and shock load that rope.
A limb or log in motion needs to be decelerated slowly. Either by allowing to run a distance or stretch, or preferably BOTH.
The technique you are using, removes both of those things pretty much.
So what does it do?
1. It stretches that very short section of rope.
2. It shock loads not only your rope, but also your tree or tree limb.
What is going to happen?
Well, you already saw it with your old rope.
Your rope will loose it's stretch and fatigue quickly. It might even look new still, but it will snap.
Or, one of these times your limb or trunk will be too thin or have a defect and snap.
You need the piece that you are cutting, to be short enough to give room for a groundperson to let it run and slowly decelerate that force. You need airspace before the ground or object you are avoiding.
To do this, you need to get up higher so that your limbs aren't near the ground simply after hinging over.
Also, you need to use a very long length of rope used IN the system, to absorb and stretch. To do this you need to use a block (pulley) or X-Rigging rings
and a lowering device or at least wraps on the trunk.
The only time I do what you are doing is when I need to secure the butt of a tree I'm felling so that it doesn't bounce up and hit a house or maybe slide down a hill. In those cases, I use a thick chain or a junk huge bull line that we never use for "in-the-air rigging.
using the technique you are asking about, multiple times a day, is asking for something to break. It's crazy. That's why so many people freaked out about it, because they understood what you were asking.
I was doubting that it was true.
That should only be done in very rare cases.
