SRS and MRS length
I have never not felt warm and fuzzy trusting these with my life. My buddy's winch hook broke, and I put one of these on the line since I accidentally bought one that only had a double action gate. Two years later and the gate still works flawlessly, while the 3/8 amsteel has been broken twice pulling heavy loads.
There are lots of different and I think perfectly acceptable methods for connecting two lines, and I'm also a fan of the zeppelin bend. I do wish a tree-guy with a break test machine would make a video testing the various methods and share those results. I'd love to do it myself, but I struggle to find time to even cook dinner, let alone make a scientifically valid test on life-support methods....
I’m going to buy another rope because I’m thinking about trying to get higher on open air SRS. Not that there’s anything wrong with my 150ft hyperclimb thats 2.5 years old with light use. I’m debating about a 120-200ft rope. Typically when I SRS, I’ll canopy tie with a Quickie with an Alpine (long tail or stopper) if too high, I’ll tie a 1k paracord to it for retrieval. If I can change over to MRS for decent, it just seems easier if my rope is redirected. What do you big tree guys 100ft+ guys do with rope length? I probably should specify that if I Rec climb, I want my TIP high. If I’m working, then what ever gets me to the work area. Thanks in advance. Craig
If you can knot block your line in a Rr Friction Saver, you can tie your retrieval cord onto the knot block and pitch it down. Now you’re pure SRS that will retrieve through infinite redirects.
Another option is to join two lines by Zeppelin Bend set at the TIP. Base tie one side and climb the other. When you get to it, untie the Zep and dump the base side.
