- York , Maine
Dustin, a drift test is not just shutting down the power source and pulling the lever, first set up the truck where you can leave it for at least a half hour (lunch time) set the boom in different positions to test the different valves, over back for the upper boom upper cylinder, over the cab raised upper boom a little, lower in the cradle for upper boom lower cylinder, lower boom out of the cradle upper boom stored in rest for lower boom cylinder. In these three positions measure the distance from basket to ground or cab and let it set, have lunch remeasure any movement over a couple inches the valves need adjusting probably not replacement.
Get a lift manual. Cable inspection just as important look for fatigue breaks wires separating with a space in between, more important valley break where wire sticks up from the valley of the twists valley breaks show the cable was exposed to too much stress. Give me a call and I can send you a manual and explain some of these important inspection procedures. 207 451 8201.
Mike Lee
Mike Lee
