Serf Life
- Maine Island
That's been our experienceYou need to keep heating and beating it out with a large sledge. It takes a bunch of heat and I spray with penetrating oil. It’s a bitch of a job. Took 2 hours to get the last one to move on my ditchwitch
no snap rings and no moving parts on what's left. Just a tight fit with surface rust, pretty wild how strong that holds.Also, not sure with your specific model, but check for snap rings. They sometimes rot off or are recessed really well. May not apply here but easy to check for.
If I understand the comment, the bearing and race are all external, what's inside the rail housing is a non-moving straight shaft/rod that accepts a bolt on the inside of the rail through a beefy split washer.The heating/cooling methods won't work very well unless you get the bearing apart. If you can get the shaft/inside race out of the bearing, leaving only the outside race in the frame, welding the inside of the race will cause it to shrink and practically fall out.
Thank's folks, I appreciate all the speedy input.
