I think it is well worth the money. Ergonomically, you can set the winch at the exact right height you want to be using it at, as opposed to just using the strap and having the winch laying on the ground. That alone is worth it to me if you are doing more than one or two pulls. The tiny bit of height advantage also helps more than you might think. As far as protecting the tree, it seems to do just fine, as good or better than a GRCS tree mount. Our firs have very tough bark so there isn't too much to worry about, but something else to think about is that in most cases the force will be a straight pull, transferring a lot of the force onto the wide strap that wraps around the trunk (as opposed to say, negative rigging on a GRCS which wants to pull upward and potentially slip). If you ever needed/wanted even more protection, you could add a carpet scrap under the strap as well.
Something else I really like is using the tree mount in combination with the vertical-pull winch support ( https://www.portablewinch.com/collections/all/products/vertical-pull-winch-support ) since that allows you to easily turn the winch around and hang a block in the same tree you are mounting the winch to. And as you know, that added height really improves pulling ability. The only downside, is it is a bit sketchy getting the rope around the drum, watch your fingers....
If you haven't watched their videos, this shows and explains a lot. And they have a lot of new winch models out since I bought mine.
