point being direction of force is at least if not more important that the magnitude.
My guess is the diagram illustrates that, with a basal anchor where the anchor leg is at an angle, the force on the branch is less than double the load. I recall a thread mentioning putting the basal anchor on a different tree to take advantage of this effect.
... But, many limbs , especially long leveraged horizontals are not pure round,
but rather finite materials are allotted to maximize a/n to the most loaded axis(just as trunk and roots do), many times that is the vertical as the long axis on horizontal branch. So branch may be designed/exercised to hold more vertically than angle pulls. This is another geometry...
Voice of reason as usual. Get those vectors in compression. That is how I build rigging and climbing systems always. Creates favorable outcomes always.Nice post, @TheTreeSpyder. I would just like to add that adaptive growth is the result of frequent and constant
exposure to things like gravity, open growth exposure, or constant wind, like sea breezes. It is specifically meant for compensation of those constant forces.
While this is true and it does add strength, the main thing to keep in mind, is that wood is made from parallel bundles of cellulose held together by lignin. When lateral forces are applied, the lignin will fail long before the cellulose. Think of splitting a log; i.e., lateral force in the form of a wedge vs chopping a log, cutting through cellulose.
Loading wood with the grain, in compression, will always be much stronger than any load applied laterally.
