Looкіng not good at allIs this an oops with the new RRVertec?
Before I were to go spring for yet another Shiny New Thingy - any more opinions pls?
Thanks for the update. That sounds like a reasonable suspicion that I hope to have confirmed by enough folks to get Notch's attention. I look forward to a revised v2OK, I have had enough climbs on the Vertec to form an opinion how it handles different ropes and situations. It's actually fantastic and I love it but it does have a problem that I feel is significant.
First the good stuff. Much better in the hand without the slick pins and way faster on and off the rope. The improved spring and upper adjustable cam work flawlessly. Typical Roperunner with easily controllable descending and swing control. Likewise, going up with knee and foot ascender I can't feel any drag. It most certainly does not need a pulley for that. The lower bollard has substantially more grip than the pulley had which takes more load off the bird making the bird easier to release and enhancing control. I wear gloves, atlas 370s and can operate all the swing gates and the cam adjuster without taking them off! It is incredibly user-friendly!
But the glitch and the cause of significant discussion is in the lower assembly. It is not the lack of a pulley, though simply adding a pulley would certainly mask the issue like it has in the earlier Pro model, it is the fact that the teardrop attachment point is too short and does not clear the lower friction body when tailing the rope. When you combine that with a bollard that is less slippery and is set much closer to the friction body than the pulley was, you get multiple potential times for rope jamming and/or carabiner catching. When the rope is being tailed the carabiner should never have contact with the friction body. This is what is causing all the bad press. It is not the lack of pulley.
This, fortunately has a simple fix. A new lower attachment piece that is longer and with a hole instead of being fully routed out will allow all components to work as designed without any interference or the need to use only 'some' carabiners.
As a sole proprietor with no employees I am able to do things others may not. I also have enough experience to understand tool interactions. That said, I have an attachment that bypasses these problems. So I know how good the Vertec can be when the interference is removed.
I do so hope that RRV "running changes" aren't quietly made maybe similar to what new RRP's is/ was/ could be shipped with, to fix the hex screw stripping issue, otherwise we'll never know what we're buying - new stock, old stock, re-jigged stock? With life support equipment especially, "version control" and ability to trace thru your suppliers to purchasers/ end users in case of recalls etc. is really the hallmark of a Tier 1 equipment supplier (why I like DMM or Grivel frankly for alpine climbing gear). It's not just inventing stuff, it's having all the other attributes in place if you need them, not just after something happens. This is sadly lacking in some equipment manufacturers/ suppliers in this industry yet. And it's something I wish company's would advertise/ demonstrate capability in - for life support I'm not "price transfixed" but would gladly pay more for gear coming from a Tier I outfit I know stands behind me . . . up a tree . . . way up on some tat and a mechanical thingy. What was the line from Apollo 13 - going into space on a giant candle put together by the lowest bidder? Great feedback DSMc. Cheers all and have a great weekend.Thanks for the update. That sounds like a reasonable suspicion that I hope to have confirmed by enough folks to get Notch's attention. I look forward to a revised v2
CT really good manufacturerCarabiner choice makes a difference. Round better, I beam bad. Rock Exotica round, pretty much all of my carabiners are CT. Thinner ropes are less of a problem. It is a pretty bad miss but it will be resolved. There is a lot of discussion taking place.
I had issues with the Arbsession hitch and have gone to the Catalyon instead. More reliable engagement.In yet another RRV thread derail (sorry) - been playing with the Arbesession hitch and the Arbsession Caralink V2 tether - I gotta say this thing is pretty much the sweetest hitch rig I've ever used. Pics show 26" Donaghys Armor-Prus 8mm Sewn Eye to Eye on 11.5 mm Tachyon - it's basically Arbsession's Kit 5 with the 8 1/2 inch tether and the ArbSession Hitch. One thing I would do after reading Patrick's posts above is substitute the DMM triple locking PerfectO that comes with the kit for a DMM PerfectO with a closure DMM calls KwickLock - twist and open. This has a little bigger gate than the straight gate PerfectO and maybe doesn't flop around as much (for me anyway). Casey said he'll carry these if you want to order one so you can take the tether off and switch to moving rope just as easily as the straight gate. I also used Aquaseal (can't seem to stay away from the stuff) to stiffen up the Caralink tether to PerfectO connection (you can see this in the pic below). With couple of coats of 'flexible' polyurethane, the whole tether became essentially rigid. Cats meow this is. Cheers all
I played with one yesterday. Your comments were super helpful for me to understand where the issues is. I can see the interface where its rubbing the anodization off the biner at the contact point. Thanks for your descriptions.If you look closely at the video with the guy struggling to get his rope to tend slack with the Vertec, you will see it is not the condition of the rope that is the problem. It is 100% the carabiner hitting the friction body. When that happens the bollard cannot move away from the friction body stopping friction release. You can also clearly see that as soon as the carabiner clears the friction body, the rope starts tending properly again.
This is a situation that should not exist. Larger diameter rope will reduce clearances in this area. This is also going to be at its absolute worst on a brand new Vertec with no wear divots on the friction body. Just the understanding of what is happening gives you the ability to avoid it through careful attachment selection and slack tending technique. Even with this issue, I will continue to use the Vertec and see how or what changes over time.
Pitch is a bitch and the enemy of all things that slide. I have been stopped dead in my tracks hitting sap even on a Unicender, which I consider one of the least sap sensitive climbing devices. One of the many things I love about SRS is the ability to minimize the tree to rope contact, thereby avoiding that crap as much as possible. If you do find yourself jammed up, don't be afraid to use a solvent to clear the device and rope. Even a small dab of chainsaw fuel will quickly remove sap and not hurt your climbing line.
Thank you Steve - I shall give the Catalyon a try too.I had issues with the Arbsession hitch and have gone to the Catalyon instead. More reliable engagement.
Snakessssssss bendsssssss !There's wraps, braids like in a VT and needs-a-new-name's at the bottom of that hitch. "crossed lumps" (?)
