ATH
- Findlay, Ohio
I assume you just wire that into the unused prong on a 7 prong harness?
Rotate your saw in the cut so that you finish the cut using the part of the bar closes to the power head. You get a bit more torque to power through while its trying to pinch.Any tips for chunking down firewood from the spar? The cool guys on YouTube can always cut straight through a piece and leave the round balancing on top of the spar, but when I do it I usually get pinched before the cut finishes.
THe fiberglass wands used to mark edges for plowing. Cut them 6-8" long. You can drill a hole for thin throwline as a leash or electrical tape string to the end. The rods come in two diameters to match up with chain width too.Any tips for chunking down firewood from the spar? The cool guys on YouTube can always cut straight through a piece and leave the round balancing on top of the spar, but when I do it I usually get pinched before the cut finishes.
