Daniel
Carpal tunnel level member
- Suburban Philadelphia (Wayne)
Here's a specialty cut that I use occasionally, but could be quite dangerous if cut improperly.
For the best look, set the playback speed to .25 on youtube.
Here's the description on youtube:
DO NOT try it. This video is for entertainment purposes only. I originally posted this video as unlisted in July 2016. It's a very complex and potentially dangerous cut, which is why I hesitated to show it. The main purpose is to get a top to lean slightly into the lay, then drop like a stone, spearing into the ground. I use this most often when there isn't a proper drop zone to take the entire length of the top. This pine top fits in a relatively tight drop zone. I used a remote trip cut, which is a bit tricky, and not recommended. The tricky part is cutting enough to make sure the piece will move and break the hinge, when the pull line force is applied, but not cut so much that the cut fails before I had a chance to get out of there. When cutting from spikes on rope and saddle, it is important to judge the distance the top must move to make sure all the limbs on the backside of the tree will clear your overhead space, before the top drops. The distance the tree travels before it drops can be adjusted by changing the width of the notch. A wider notch allows the tree to travel a little farther forward before the face closes. After the face closes the top can drop directly, as it appears to here, or hang on for another 5 to 10 degrees before dropping, depending on species and amount of holding wood. It was crucial to match the cuts up properly so there is not the type of overlap that will create a lip for the but to hold up on. So complete understanding and perfect cutting techniques were required. DO NOT try this cut. This video is for entertainment purposes only. This notch is used to get the top moving towards the desired direction of fall. This creates an early separation to allow the butt to drop straight down. In this case it was used to prevent damage to the surrounding trees. Pine limbs are fairly brittle and susceptible to breaking when loaded. This cut can also be used to shorten the length of the fall.
