This is the Akimbo
Hey, @hamcube! Welcome to the TreeBuzz forum! I think you are going to like it here! Congratulations on making your first post in the forum!
I do not yet own the Akimbo, so I cannot answer your question from direct experience, just yet. I did however try to use the search utility, first within this thread only, which did not help me. Then I did a general search on the whole forum using the terms Akimbo rope, in quotes, and found the following thread which I think might be of use to you. I have not yet read all of the way through the thread to know for sure, but I think it might put you on the right track.
Thanks for being a member here on the Buzz. I hope to read much more from you, and would especially like to hear back about what rope you decide to buy, and how well it ends up working for you. Jaime posted a video on YouTube that is supposed to make it easier to understand how to "dial in" the Akimbo, just in case you had not heard about that. Take care.
Tim
I bought the xstatic, and it quickly found its place as me dedicated zigzag line. Truly, I’m not impressed by the teufelberger lines I’ve used. Yale and sterling make my favorites.
I tried out @climbstihl 's akimbo (which might be the first ever one imported to Germany!) and his rope walking setup out today, It's amazing how fast you can ascend with it, especially comparing it to a RADS. I'd love to own one, but I dont think that's happening for the next few years...
The only things I needed to get used to were the breakaway chest harness, which threw me off for the first few attempts, and the rapelling characteristics which I also needed some time getting used to (I pinched my finger between the two "jaws", oops). I think a different rope would probably change the latter, I'll have to try it again when he gets his Drenaline.
Overall the akimbo is, as expected, an awesome device, great job designig it!
Drenaline is an excellent choice. Works great for me.
Bought a new climb line from a company I was unfamiliar with until I chatted to them at there comp booth. It is called braids and laces. I visisted there manufacturing facility and bought 150 feet of 11.5 mm wizard. Spliced an eye yesterday and bounced around in a 50 ft Norway Maple today on my property to test it out. This is a first impressions review, but man was it sweet. I am 185 lbs with no gear and I had my settings at f4 for my 11 mm kmIII max. Didn't change it at all and it was silky smooooth. Possibly the best I have yet to try?? At $340 CAD for 600 feet it is a steal.
Never heard of that place, but I checked their site and have decent prices on stuff.
Sorry if this has already been covered.
I'm having trouble with the akimbo slipping down the rope when using a rope walking system. It slips if I try to squat straight down but if I lean back it usually catches. It does this even on friction settings too tight for the rope (Sterling htp 12.5)
Here is what I am talking about.
Any advice is appreciated
Check to see if the upper cam is sticking
You need to:
a) shorten your tether length, raise height... get rid of the full size carabiner and use a little one like the DMM XSRE and perhaps a bungee neck tether.
b) lower the device attachment point... smaller 'biner like DMM Perfect O or shorten bridge length.
As you drop down into the harness, the device isn't engaging because the distance between the tether point and the bridge attachment isn't great enough... the 'biner isn't pulling down on the Akimbo soon enough.
I hope this helps.
