I only demoed with an owner of another local tree service near me the easy lift 7036 and was Imm pressed with many features, some things I could see would possibly( as a non owner one time in person viewers perspctive). Little beefier protection metal certain fitting near bucket attechment.As well a few other semi sensitive areas slightly beefed up At the base of the machine the hydro pump was unprotected and looked like a bouncing log could possibly cause damage in poor circumstances. The owner of this machine said he would set up higher on outriggers. As in lift tracks more off ground to protect from rolling bouncing logs, which he admitted wasn't recommended, you should keep tracks close to ground as possibly, if I'm not mistaken. I mentioned rigging to keep pieces from flying in which he sorta chuckled with a yeah..he mentioned the self level never being that good , although manually leveling wasn't bad anyway imo, you just need ground protection than a sliding board and pad to accommodate movement as setting up.I only saw it in his flat yard,he said he liked the machine overall, But in his words it althoguh he uses ground protection, he said it was the difficult terrain( of course)such very root laden land (not that common here) and slight off camber hills ( not that common with hills here)which he said was the most difficult to get the setup correct at first . Seems like hes only had a few jobs the machine coupdnt set up which speaks volumes to me , but made it clear the unlevel groumd setups were obviously the most time consuming and lots of time on certain occassions could be difficult .if your terrain is hilly that may be a major limitation. The need to turn on hills seems possibly out the question or aprroches on angles after a point plan on just to break out the Ropes and climb. You could have it done by the time you setup. But it seems over all it will be a worthy investment for sure once i free up some capital. I do a lot of pruning work on the tips and this machine will make that much faster in my market I think as cuthigh mentioned.. I feel overall the easylift has features that make it my best choice. Simple little nuances mean a lot over the life of the machine. It seems plenty fast enough in the controls to me. Some career bucket babies might think they're slow , from a pure climbers perspective I could see one of these complimenting the climbing very well. For instance you don't want to sneak these booms through the tree if your gonna touch it on anything, it seems. Although sneaking through with telescoping and articulation in jib looks mighty fun. But certain stuff way inside just send climber while lift hits the outers. I feel like there's more I'm missing right now.. if I think of more.....I realize this isn't an easylift thread it s cmc thread. I didn't know where else to place this. It was the most recent spider lift thread I guess.
