RopeShield
Carpal tunnel level member
- Ontario, Canada
Why @swingdude
Sorry, missed this B-Hi Ken, do you know of any advantages of having a retrieval shackle that is adjustable? It has been a while since I have used DdRT and I can't think of one. In fact I just disassembled one I made of tenex a little over ten years ago. Looked brand new but just got too old.
This has just been thieved.Hey... that's some fine azz line... doubles as a backup climbing line and light duty rigging rope. Ok, the box does suck. I'm thinking of upgrading to a Walmart shopping bag or maybe just drink more coffee so I can empty out another one of these...
Plywood beneath, and tying tires together, worked for repetitious bombing of chunks onto pavers.I've used a collection of old truck tires placed on top of a concrete sidewalk for protection from a small/medium sized stem being felled. It worked great to prevent cracking the sidewalk accidentally. Effectiveness of this trick would diminish as the size of the tree increases.
Tom you make good points.
With MA each part of the chain needs to be examined to check the load. I totally agree that friction hitches are much more rope friendly.
I think one very important point here in pre-tension to the porti is that you begin to mix climbing gear and rigging gear, keep them separate and I think a hand ascender will work in this 2:1. again, like you said a prusik or friction hitch is probably a better idea or a rope grab that will slip first like a shunt or other toothless rope grabs.
The Petzl hand ascender is ok on a 2:1 and has a breaking strength of 6.5kN or around 1400 pounds. Probably not going to get exceeded from a couple of guys giving a pull and it is quick to install. The wire gate revolver also would work here IMO.
Again, good points Tom and maybe some things guys don't think about much when you start to work with MA.
