I wasn't a big fan of it before. Not that it's a bad tool, it just wasn't interfacing well with me and my ropes. But I tried it out again on my new rope and presto, I really like it now.Hey Mac...This sentence caught my eye. What does this mean?
Thanks.
Let's just say I know people. Hopefully you won't need to know anyone to get this diameter soon.12.5? I have not seen such, where did you find it? Firm ropes and akimbo are buddies.
While the tending shackle is rated for 500 lbs the way the lower cam interacts with the weight of the climber makes it impossible to use as a ddrt attachment point. It is the same with the bulldog bone and the roperunner.I will be making this purchase when it becomes readily available. I have a quick question .... does anyone know if the tending shackle can safely be used for a Ddrt tie off point. Would this negatively affect operation of the Akimbo? Looks like it might be bad on decent. It would be nice to clip in like a ZZ.
"The Fly" Affordable kernmantle that seems to fuzz out nice with age (for grip) but still compatible with 11mm devices like Eddy, Rig, Pantin, Unicender, and yes even Akimbo!...
The FLY, FLY II, and DragonFLY. I'll agree, not such a bad rope at all, until you want to splice it.Bulky and ugly finished eye, but still strong enough. Word around NERopes is that was the downfall of the rope, and the reason for the birth of Tachyon. Tachyon definitely stays rounder than FLY, which is a real bonus for mechanicals.
Dare I even ask? Has anyone tried it on KM3 13mm? Does it have that extra half a millimeter of adjustment to fit this fat, blue bastard? Even the RopeWrench is so tight on it, I'd have to eat cheesecake 5 times a day to get up to weight to descend on it. Then I wouldn't be able to back up, again. It's a nice, firm 32-strand kernmantle.
Mert, it may be the memory that makes a difference here...or at least for me, since I probably weigh half again what you do.I would agree the bulky eye is a bit of a pain. I have found the stitched eye is less of a problem but not ideal. As for flattening I would have to disagree in my experiences. Tachyon flattened and hardened very quickly when wrenching for me. So I switched to fly and have not found that to be the case. I wish @monkeylove would give me his akimbo so I could see if it reacts differently. But for now I gotta wait.... I like fly with my wrench and runner and have been happy so far.
Frank, was that before or after I took a couple locks and hung for a hot second? I was thinking it felt a little draggy going up and a firm to release...No problem Steve. Now when I was at Aerial Rescue with Eric I climbed on his Tachyon and had to go to hole 4B.
Do you have an idea when gofund versions will make it out?
I took and akimbo and pulled nearly 3500# and no slip now it was adjusted quite hard and prob would not tend well at all. I started to disassemble HTP with it at nearly 9500.Have or do you plan to do any drop testing on the Akimbo? I mean like if a 200 lb. guy fell off a branch and it was shocked at say 4 feet that wasn't tended...that would be a 800# shock wouldn't it? (doubles every 2 feet?)
