123Craig
Started removing slightly bigger (generally single stem) trees recently (when I say bigger, it's nearer 100' compared with 80'). After limbing the trunk as far as the bucket can reach - I climb from the bucket to work on the remaining tops. I've been doing these tops spurless as the boss preferred I do it that way (and I do too right now), so I generally leave enough stubs to make a ladder of the top. My question specifically is this; if you look at the picture below - is it safe to rappel in this way to reach the ground? - ie, I think it would be extremely hard for me to flick my friction saver off 1' length stubs on the opposing side that I am descending on. Thoughts?
One more question; say for instance I was descending in this (DdRT) and I realised that I was going to run out of rope. Would it be a viable option to stop rappelling just before my stopper knot in my climb line, choke my lanyard around the trunk (while probably bracing myself against the trunk by trying to wrap my knees/legs around it in a manner - if I had no spurs). Pull down/out my DdRT line, then choke it SRT with the tail long enough to reach the ground - then just descend on it again? - I realise longer ropes (and spurs) would lessen the need for this option - I was just wondering if it still could be done fairly easily?
All the time (and money) I've spent on gear, research and testing is really beginning to make much more sense (and work easier/faster) as I climb higher. The views up at the top get better, I'm more stringent with checking my gear/work practices the higher I climb (I think that's a normal thing for any climber) - it's a mixture of 'Fuck sake, I must be out of my fucking mind to do this job...' to 'This is amazing - not many people will ever get to experience the intimacy with the trees at this height in this way...'. I'm discovering how easy and fast it is to bomb out the tree with the Bulldog Bone in DdRT - the boss is pretty impressed, even though he complained once that I almost landed on him - nonsense, I had it all under control - he's just not used to seeing me rappel so fast. ; ) I never thought I'd be able to bomb out the trees like others can on youtube, but now I can. I know that many are interested in the peak forces when you bomb (or shock load) in this way DdRT and SRT - I too would like to know more...
Thanks
Thanks
