Evo
- My Island, WA
For clarity, I have already exported the CSV. The issue is in my area the city addresses go well beyond city limits (literally 4 miles outside of city limits) has the same postal address and zip.@evo, I have no idea how your client list is currently stored or what software you use to create and maintain it, but there should be an Export function somewhere that will create a CSV file of your data which I assume will contain your client addresses in addition to other data. It sounds like you want to visualize your clients on a map. If that's so, you can import your CSV file in a personal Google Map that you create (links below), and it will place a labeled marker at each address. (You may need to remove all columns except name and address fields from the CSV file first.) You will have to zoom in to manually find the ones that are within that city, and I'm not sure what you will do at that point. I don't know an automated way to select those clients or if there are too many to manually select from your CSV file. I don't know if this helps, but I thought I would throw it out there just in case.
Create a personal map: https://support.google.com/mymaps/answer/3024454?hl=en&ref_topic=3188329
Import data into your map: https://support.google.com/mymaps/answer/3024836?hl=en&ref_topic=3024924&sjid=4847907390728716555-NC#zippy=,step-prepare-your-info
The city has a GIS map which shows city limits, but no way to import or search for bulk addresses to see who is in or out.
I found a way to import my CSV into Google Earth Pro, and apply a city limits layer. However I cannot group select the pins within city limits and export these into a CSV (or anything) to figure out who is in city limits or not.
Only manual options of single address search at a time. Over the past decade I have about 450 addresses which I believe are in city limits.
