The difference between logging and Suburban Tree Work
While you can go with less in the middle you must increase the thickness. I haven’t found gutting the center of the hinge as having any more or less benefits other than being able cut with s shorter bar.
Around here our big bars are typically 28-32” wrap saws and cutting the bad side first. Really no need to cut the guts out as we all have bigger setups on the truck. Out in the back 40 is where the tricks come out to play…
Are you pounding wedges, using ropes, or both? And what are you pulling with... the noticeable advantage to gutting the hinge requires a lot of pulling force. 3 guys on a rope isn't going to cut it
PS... if you believe that the tapered hinge has greater holding ability, then the gutted hinge is a logical extension of the effects from putting more hinge fibers on the tension side of the hinge
Davidwyby, glad you discovered the monotonic teacher voice nerd videos. I really appreciate when a guy like that makes the effort and has good quality. I watched his whole series some years ago :)
On the stress neutral axis - its a dividing line, not a region. So it's actually a mistake to call a central (e.g. 1/3) region neutral. Whatever you cut out is either tension or compression and in his assumptions case linearly distributed per his earlier diagrams. Depending on the amount of side lean locates the axis line. And cutting central wood out adds that previously located-there load/stress to the remaining wood.
Some observations from his videos are that in compression you have headroom safety method from the crushed fibers still having compressive strength due to geometry. On the other hand if you start breaking tensioned fibers when right at the tensile limit you immediately overload the remaining tension fibers which in turn fail leading to a cascading catastrophic failure - "losing the hinge". And the tension fibers are what restrains the tree from swatting the targets under the side lean. Guess what wedges contribute? tension. Pulling contributes compression. A possibly useful insight.
He goofed a bit on kick back by citing only impact with another tree as the cause. The basic cause is that during the fell you're taking the CofG of the tree/spar from above the stump and shoving it sideways to laying-on-the-ground position - and giving it enough such shove to develop sideways kinetic energy to boot! Where does that shove come through? The hinge. edit - hockey stick or broom handle vertical on your ice rink - tilt it a bit and watch the base (with no restraining hinge) scoot out sideways!
His next video IIRC explains the crush/tensile failure during fell and is the basis for my earlier comment about diminishing returns by swapping out central hinge load bearing for fatter hinge posts - the fatter the posts the more strain per degree (directly!) of trunk fell and the more fiber failure.
It is an idea to back up a possible tension post failure with retaining the central hinge - statistics and freak failures:)
Daniel have you ever taken a tree to the point of experience, a failing tension post? What factor of safety do you figure you operate at? x1.5, x3 x 5 or? I'm guessing substantial if you've never popped a post in tension.
Please note!!!!
I didn’t write this comment. It was sitting in place for some unknown reason. I thought I was deleting but it posted. The Ghosts in the Machine are restless. Should I call The Police
This ^^^^^^^^
Terry Hale is a treasure. I love his sense of humor too. I even watched his "Chainsaw advice for single ladies", and his boulder moving saga. I have moved many boulder that way too.
You could be his disciple, or maybe his twin... "tree nerds" ;)
Nothing wrong with that.. a lot of it's just over my head... so try bringing the vocabulary down a little closer to the working man's if you want me to understand what you're talking about... While I was surprised that I didn't ace the math SAT, those days are long gone, and I got an ADHD-type attention span now... For example "factor of safety".. I'd be guessing if I had to tell someone what that means related to falling trees, though I do have a concept of "safety factor" in ropes.
Hale is not perfect (by a lot in some areas) but this is one case where I'd give him a pass on the details. His basic point is valid in a practical sense, though technically incorrect as you point out. The practical point is that it's not a 1:1 trade-off. The little bit of side-holding ability you get per square inch of hinge in the middle (near-balanced area between tension and compression sides of the hinge) is far less than you get out of a square inch of hinge near the corner of tension.
I don't think so. If I have, it was backed up with a retainer line. I know I have heard hinges pop before. That's how you know you would have lost the tree without the retainer line, which is a great way to learn how much you can trust a hinge in that given scenario. I AM pretty sure I would have remembered if any of those times were using a center plunge.
Here's one we were fighting a huge and heavy side lean on... Probably should have a had a guy line on it, except that was going to be hard to rig... look carefully to notice the oak that's already down has another center plunge and very small posts
The risks I AM willing to take are inversely proportionate to the value of the objects at risk. I was 50-50 (or less) on the dead oak in the above video. You can't really tell from the video just how heavy that tree was leaning. I would never have made the cut without a guy line if there was valuable property at risk. I was actually surprised that it held.
In this scenario, there was nowhere to anchor a guy line except across a busy road, and there was zero way that was going to happen. And the object at risk was a sizeable Norway maple, that was just a wild tree growing on the edge of the property. I had a very good long-term relationship with the elderly client who was just about to put the house on the market. If that maple had been damaged, I would have had to go to the trouble of cleaning it up and grinding the stump, but no other consequences. And I had already saved him a ton of $$$ by falling the trees when all other bids were for rigging or craning. So it was a low-risk scenario.
When it comes to making a cut that might injure/kill me 1 in 100 isn'r good enough. It's got to be 1:1,000 or less.
no, I don't think I have even left any comments
Here's a video on pulling trees with ropes from Terry Hale where he analyzes the difference between pulling with dynamic vs static line, giving the example of pulling with 3/8" line from the hardware store. I don't know anyone that would use such a light light line, and then he proceeds to calculate the speed at which the rope would recoil if it snapped... that's a ridiculous exercise in geek calculations with no real world value. He's at 7 minutes and still talking about ropes before he mentions anything else. And then it's how to tie a rope to the anchor tree. He never mentions how to set the rope in the tree, the importance of height, pretensioning the line to check for movement, how to rig a 3:1 rope come along without pullies, the use of vehicles, knots etc...
He's well intentioned, but lacks the real world experience necessary to teach professionals.
I've connected Terry Hale and Daniel in the same universe - the Force is with us.
David, you want to punch up the whole trunk moment of inertia vs side loaded direction standard hinge vs center 1/3 gutted- the answers would be 100%, ?% and ??%. Apparently there's also two felling hinge standards 1/3 depth 10% wood etc. I'm too lazy :)
The 1/3 or 80 % diameter is just a beginner's guide. I would hope with all the video out there that most of us have gotten over it as some sort of golden rule. Plenty of reasons to go deeper. Some reson not to go shallower, and sometimes shallower is acceptable. Way too many variables to make that rule stick.
And the10 percent hinge thickness standard teaching is nonsense... almost never a good idea imo
