Evo
- My Island, WA
I use a running bow 70% of the time, timber 20% and a cow about 5%, wrap 3 pull 1 5%
"Massage" it throughly with a rubber mallet on a clean surface, changing where you hit it each time...If that is a link in your post, I can't get it to work.
I would think for two reasons. 1) Harder to untie. 2) With this I may be wrong, but I suspect it to be true that the knot would weaken the system. Knots usually case the breaking strength to be reduced in a rope system, whereas a cow hitch or timber hitch does not weaken the system as much.
My 2 cents, for what it is worth.
ps: I have a 5/8th 200' hank of one time used Polydyne that has a bowline on a bite locked up right smack dab in the center that I have not been able to untie for about 2-1/2 years now, but I keep trying.
Thanks for that advice, but have beat on it with a rubber mallet, a carpenter's hammer, and a 3 pound sledge with no luck. I have spent way too much time trying to undo that knot. Cut it out last night so it is now a mute issue."Massage" it throughly with a rubber mallet on a clean surface, changing where you hit it each time...
or grind back and forth with a clean boot on a clean, smooth surface.
I am with Ryan here. I will use a running bowline if I am improvising a hitch with a short section of rope. Directional loading is one concern, but for me it gets loose when not loaded and the Porta wrap creeps away from the tree. I hate any more slack between device and tree than absolutely necessary.When teaching rigging I always tell the trainees that my preferred method is always the cow hitch because it can handle multidirectional loading, easy to untie, and strong. The disadvantage is that it uses a lot of rope. My second choice is a timber hitch. It doesn’t use as much rope, is strong, but requires you to think about direction of loading. A running bowline is an acceptable option that uses even less rope than a timber hitch but will tend to move around more so care needs to be taken to make sure that this won’t cause issues during rigging operations. One way to limit this is to make the eye that goes around the hardware end of the sling as tight as possible or get creative with some prussik slings.
O,you using sticks tooDave, I have used a stick in the bowline when anticipating a hard pull before. Helps to untie. A tapered marline spike would work even better.
For tying the running bow nice and tight to the trunk, I re-dress the knot like this:
Bowline variations took on some users with sport climbing where many lead falls/ catches happened without untying.Figure 8 follow through was the standard when I learned to rock climb in the early 1990s. Bowline was for sailors.
In a situation where you need to anchor a portawrap with a dead eye sling, it has usually been shown in the past that the only valid options are a cow hitch or a timber hitch. Years ago I made a video showing how I set it up using a running bowline instead, but I got a lot of pushback. Lots of people online said it was inappropriate to use a running bow for this. I disagreed then, and I still do. Does anyone know why a running bowline is no good in this situation? Same question for a ring as a redirect.
Breaking load of hitches and ropes used in rigging
Hard to untie after loading?
How are you attaching your figure 8/9 to the fixed end of rope?Figure 8 or figure 9 for me on a base tie. Have been known to use an Alpine Butterfly, but not the norm. Don't use a Bowline on a base tie. Bowline is probably one of the least knots I use in climbing or tree work. Use it on the catamaran when racing, but not climbing.
Figure 8/9 is on the end of the climb line. Steel carabiner from there to an ultra sling around the stem. That is if I don't incorporate a Petzl Rig in the system. Often use the Rig as an option for rescue. In that case the climb line goes through the Rig with a simple slip knot afterward as a stopper, but easily untied for rescue. The Rig then is steel carabinered to the ultra sling. Recently added a screamer in the system between the Rig and the ultra sling, which proved to be handy that day.How are you attaching your figure 8/9 to the fixed end of rope?
