That looks like a minimal gear system, YoYo. I intend to be constructive with the following critique...
If so, my concern is gear alignment/orientation....
....Ensuring that your connections will orient properly without help from you throughout repeated loading and unloading would be key.
I'm just reminded a bit of flop factor issues with certain base anchor systems, and the importance of proper orientation.
Thanks oceans,
First of all, critique and constructive criticism are always welcome, isn't that why we are here, to share ideas and improve on them or help others because we have an idea? If all a person heard was, "great idea", what would they benefit? Now negative criticism I think we get enough of elsewhere and if I want ridicule I can always go to another forum.
Your points are well taken, I just started using these tethers and you gave me some good thoughts to improve on them. Yes this is a minimal system because it is using the two points of my ascent system to walk without adding a third. When I do long ascents or just normal rope walk also using my hands, I'm am attached also at the bridge with a croll chest ascender and it is tended with my neck lanyard. When I start passing limbs or need my hands to maneuver I remove the neck lanyard from the croll, attache it to the Uni, adjust my tether and foot loop and start walking.
suppose I could add another HUT
I agree it is not a fall issue or the same as an out of reach and sight base anchor flop problem.
I look at flop as a management issue more than an elimination issue, kind of like stress, bound to get it, just have to manage it. The Zigzag is a prime example, even under specified conditions, had the flop been managed with a keeper, I don't thing that accident would have happened and everyone would still be zigging and zagging.
I have attached a link to a photo.
On the left when I was using my ABR tether I managed the flop with a ball lock carabiner, a keeper and self bonding silicon tape and a bungee.
On the right I have improved the new system securing the tether to the Uni and trapping the duck with keepers on both sides. As a note, the new Rook pulley I'm using on the bridge has built in grommets that securely hold the biner in place.
Again, thanks for the input! Although I'm pretty sure as soon as I get this all dialed in I'll be trying something else. (Wish I could be content DRT on a blakes hitch)
managing flop factor
