I have a question for any climber out there that may have experimented with the VT in the way I have for the past couple of days.
So, I've been using the VT for quite some time now but I always found myself complaining about having to tend my slack as opposed to the blakes hitch where you would advance your hitch as you climb. I recently tried to solve this problem by adding an eye to eye from my saddle to my VT system. This allows me to continuously shag up the tree without needing to tend my slack. ( I use a hitchclimber pulley so there is one attachment point). Obviously, once I get up the tree I take the eye to eye off and continue to climb normally on the VT as is. But as far as shagging up the tree initially I really like this eye to eye idea. The only down fall is that the VT is out of reach and if an emergency were to happen you wouldn't be able to descend.
For this reason I am assuming I should not be practicing this technique? Any thoughts?
