- healdsburg, CA
Not to hijack the thread, but....
The most comfortable spurs I have ever bought have been the Carbon Fiber spurs. Got them overseas. They are modeled on the Geckos. The cardboard box & foam 'peanuts' they were shipped in weighed more than the spurs!
Part of what makes a comfortable spur is proper setting of the shank or hight of the spur. If your spurs are adjustable, try raising them as high as they will go. Use them for a bit and see how it feels. Play around with the adjustments until you get it right. But I personally would start with them set in the highest/longest position. Usually the top of the pad should sit right underneath the knee joint.
If your spurs have straps that hold the pads to your legs, try checking them out and see if there is excessive movement- correct that movement to minimize it as much as possible.
Just as important is the type of boot you have. Dont expect to whip out your weekend warrior ultra light hiking boot and think the shank will support the arch of your foot all day long, especially working a bigger saw.
You must adjust your thinking when using spurs. Usually when you have the spurs on you are doing heavier work, so use a heavier boot.
I see that all the time, guy going up a removal tree using the same tools, mindset, and methods they would use in a pruning operation. Those types most always are slower, dont visualize piecing out the entire tree, make silly little cuts with their handsaw, set up weird roping paths, using crotches to stand in, not being skilled enough to stand on any side of the trunk no matter what the lean, the list goes on and on.
Spurs are comfortable to wear all day. IF you have them adjusted correctly, and IF you have the proper footgear.
If you believe what I say, change your thinking, and learn, you might find out that your experiance wearing spurs will change for the better.
I went for years with a permanent bruise/raw spot on the side of my leg. Then a more experianced climber checked me out one day, laughed at me, called me a damm rookie, then took me in hand and showed me how to do it right.
