- napanoch ny
Top notch grapple if u don't know who Dave is lolAvant or cast with a Dave norgaurd grapple u will be killing it
If money isn't a concern, and the hydro rotate can free spin. Get it. 97% of the time the none rotate isn't a pain in the butt at all. I would rather have a pin or some stop to lock the grapple at 180 and 90 degrees.
I don't think this would help, some way to tip the grapple up would be SWEET! Just drive in to a small tree or shub, pinch then cut.
My implemax grapple on my swinger is free floating and it was never a problem with putting the grapple wherever it had to be, although I have 16 years experience with it. The grapple does have a stop built into it.No rotation is fine
I’m just wondering how many of you guys that are not using the rotation have used one WITH rotation? Because yeah, you can certainly get by without it but man it makes things easier with it. Just makes you look more elegant.![]()
@tnttree
Dave,
Have you considered putting out a BMG Tips and Tricks video? It would change a lot of people's perceptions about the dangle grapple.
I've figured stuff out that others probably have, but not everyone. Likewise, others have figured out things I haven't, presumably.
Working your way out of a mudhole, without tipping over,
Do you have a tips and tricks video?Elegant ? have you ran a knock around grapple?
talking with many guys over the years who are trying to decide powered or non powered
"This is America! of course I want the power"
I believe they have the following myths in their heads
A powered rotator will hold a load -
false - all rotators bleed internally so the unbalanced load will float to gravitys pull
as with the locking pin, if it locked the leverages would tear it or the grapple arms up
Rotators free spin
false - they slowly bleed to gravity when not activated, they will turn but act like a break slipping slowly (think like a brake 90~95% applied)
Powered rotating will give you exact placement when grabbing a load, so your very first experience with these style grapples you will feel more comfortable and gravitate towards the thought that you have to have it, where as the knockaround takes a little more operating time to get it to do what you want, so at first you might get frustrated especially with your buddies watching.
What's hard for 1st timers to understand, you have to actually run the rotator - another switch and lever or 2 levers to work during the forwarding processes. Not a huge deal you will learn how to operate it, the thing you probably won't realize is when forwarding with a knock around, most times, you won't have to operate the switch and levers. During chipping the powered rotator will slow the operation down - because you have to run it - IF the rotator could free spool, then this would not be an issue,
Powered Rotation is more important the heavier the machine you have, these new monstermini "middie" track skids can be so destructive to turf, so exact placement of the grapple will compensate for the less experienced operator.
Hard to argue with some people over the power rotation issue, so I make the BMG with power and it is unique over all my competitors, because of the receiver, 3" bollards, and the optional clam and rake
Tease,
over the years I have gotten some great Ideas to add to the BMG from users - the receiver hitch, bollards, tree pusher, saw scabbards.
there are several other ideas pitched to me by owners, that I believe will work for us professionals. I just hired an engineer to get these add-ons developed - give me till summer, one of these Ideas should be a hit.
we have our own Grapple now.Top notch grapple if u don't know who Dave is lol
