Re: \"Extreme Rigging\"
I guess it would also depend on the type of wood right? I know that ripping pine is a breeze, whereas some hard woods are a pain either way you slice it. I am imagining those long fibers just coiling out flying down the cut. Very little physical labor on the cutters part. I think I was thinking more about the cutter than the saw. Abuse the saw, it doesnt have feelings.
Chunking wood is one of the hardest most physically demanding parts of the job that I can think of. Hauling around those big saws in trees is absolutely insane, ask anyone in the world and they will tell you. Its absolutely crazy.
I am thinking that once the saw enters the rip cut, your in a fairly safe position. Your still crazy though. All you would have to do is hold the saw and somehow manage your hitch as you cut your way down to the bottom. Interesting problem to work out or maybe not.
I wonder what the math would be as far as the length of the cuts that you have to do to get to minimal size needed to rig it out.
Theoreitically, you could rig down up to your working load limit on your rigging. That would take a very long bar or two cuts.
HUGE chunks. I would assume that the size and weight of chunks correlates pretty well with the overall distance cut through the wood. but I am not sure. I am starting to confuse myself.
If this hypothesis is true than in this method, you would cut less distance by ripping off huge cuts than cross cutting and shock loading little bitty chunks.
The big ole chunks could then be picked up with the GRCS and guided by tags into the bed of your nifty bandsaw mill you have waiting, or onto whatever rolling or sliding device necesary to take it to be further proessed.
The next cuts, as big as you can make them, would just leave enough standing to manage the last load.
Then with the skinny little beam you have left, I dont know, put a bird box on top.
I have an estimate out on an 30 inch ash tree growing through a deck next to a hot tub and garden boxes etc. If i get it, am debating giving this method a go.
I have been getting more and more used to the idea, and enjoying it, that time is pretty low on the priority list when approaching a job. Thoroughness and sanity (meaning fun) are far more important. Thats been a pretty common thread spoken here on the buzz that has been good for me.
