DIY Pack Wheel for heavy gear
Like I said, Dad and his hunting buddies made a single bicycle wheel stretcher type for deer hunting. I've pushed a few tons of materials in single wheel wheelbarrows and some in two-wheel setups. For winter camping I had a heavy duty pulk that I pulled for hundreds of miles over the years. On lakes mostly but some rough and tumble portages too.
Deciding which wheel configuration seems to go with the terrain. I think that @Burrapeg said rough terrain and skinny trails is easier with a single, large diameter. If the trails and terrain is more tame smaller diameter and two wheels seems to be a good choice.
Beta versions of all of this can be fabbed with electrical conduit. Hammer and anvil and some quarter inch bolts will work if you don't weld.
Be sure to start the process with your CAD system though. Cardboard Aided Design along with laths and hot glue work well in my Skunk Works Facility.
I gave up on my single wheel borrow 20 years ago.
I used as much effort to keep it up-right as required to push it.
Instead I bought a 10 cu. ft. plastic tub wheel-borrow w/ 2 wheels !
I inserted wood spaces to move the axle down.
Installed small car tires (wider - for wet area, & stability; larger diameter - for divits, holes, branches, logs, etc.)
I've used a 2-wheel wheelbarrow before and didn't like it at all. In my experience, much worse than 1 wheel when going across a slope; you have to torque the handles enough to get it on the uphill wheel lest you dump your load. On reasonably level ground, 2 wheels might be great, but it's in short supply at my house.
Somewhere I have drawings of a Rail Sail bike after I found MANY miles of abandoned railroad tracks down in AZ.. The plan was to make a bike trailer that disassembled into two axles and 4 wheels. bike in the center, and each wheel would have a arm that would lock to the tracks with a skateboard wheel. The sail was suppose to be from a sail board. Sections of the tracks were torn up on either side of town, so this would break down into a normal bike and everything would ride as a trailer across town..
No not really. It would be interesting to see like wind sailing with skateboard and catamaran type sailing board on a road or parking lot.
I dont think its gonna catch up as huge sales but I'm sure someone like to buy it from you .
let's say 30 units a year state wide a most ?
But yeah it's a derailed subject from this thread in a way ... Lol
And "derailed" was a bad joke too...
Here is a youTube vid of one of the commercial hiking wheels, showing it on narrow trails, going between rocks, etc. An apparent advantage, albeit a minor one, of pushing one rather than pulling something, is seeing exactly where you are steering it in really confined places.
Walking a unicycle down a trail just looks goofy. Watching the vid, I'm thinking you might as well be walking a bicycle. Oh wait! If it was a bicycle, you could ride it. Or if you're a badass, you could do it this way
Personally, I like the tow-behind model, since it's hands free.
Oh I totally see the advantage. I’m just thinking of a wide(ish) yoke that folds down like a kickstand. With caster wheels.
I once had 4 over flowing pickup loads of bikes and bike parts, plus a bottomless dumpster of fire extinguishers and a forge/mig welder…. 93F03A00-0086-44A9-A262-6EB6C0386D63.jpegE765C8C5-D384-47AA-8CDD-CC5AA30BC18B.jpegE20B54F0-7C75-4AF6-889F-0CE086FBD784.jpeg
