Ditch Witch SK500 too small?
According to the dealer it is. Not sure on the engine swap. As long as the bolt pattern and output shaft were the same it would fit. Wiring would be another issue as well. Might be worth a call to a dealer.
When I repowered my dingo 220 with a larger gas engine it required quite a bit of research but I eventually found a larger engine that was a direct fit. It was worth the time.
I have had one of these little guys for about four years now. I am consistently amazed by the work it can do. The best feature of this little guy is it’s stability on steep hills. It has an extremely low center of gravity compared to most tracked minis, as well as the tracks being set fairly wide apart. I do wish for slightly more lifting capability at times, but for the work we do in tight city lots with 36 in gates, it can be used on pretty much every job.
